Stall and loss of power
Posted: Fri Jul 16, 2010 10:11 am
by Gil
Hi,Today I pulled out of the drive way and my 06 Vibe with 64,000 kilometers stalled. It took several tries to get it started and when it did there was almost no power. Pedal to the floor and it barely revved at all. If I took it out of Park or Neutral it would sputter. The Check Engine Light also came on.So I let it sit for a few minutes then it started right up, full power and but the engine light was still on. I drove it for about 20km, and when turned off the engine and restarted, it was fine and no Check Engine. What could be going on here?? Is this the dreaded PCM problem I have been reading about on here?Thanks,
Re: Stall and loss of power (Gil)
Posted: Fri Jul 16, 2010 10:48 am
by keithvibe
any mods done/ cai ect?could be a vacuum leak, have you had any recent engine work done?
Posted: Fri Jul 16, 2010 10:18 pm
by Gil
No, on both of those.
Re: (Gil)
Posted: Fri Jul 16, 2010 10:36 pm
by lovemyraffe
Can you give a few more details? Is the engine acting funny, can you get the motor to redline while in gear? If you can get a CEL back, get the code. That will help diagnose it.
Posted: Fri Jul 16, 2010 10:38 pm
by DiveNut
Initially it looked like you may have been in "limp mode" and perhaps a bad MAF sensor. But the fact that it runs OK now eliminates that. Perhaps an ECU type thing? It will be pretty easy to diagnose the problem if you can provide teh CEL code.
Posted: Sat Jul 17, 2010 12:00 am
by keithvibe
first I would reset the ecu. disconnect your battery for a few mins. Reconnect it and let us know if it's still happening. It takes the ecu a few start stop cycles to relearn.
Posted: Sat Jul 17, 2010 4:01 am
by star_deceiver
Almost sounds like you had a little water in the gas tank. Sucked it up, sputtered, ran it through and now it's fine.
Posted: Sat Jul 17, 2010 5:02 am
by Gil
Happened again today, but this time it wouldn't even start until 3 or 4 tries. Same as before, once started wouldn't rev past 1500. when it was running, the rpms would fluctuate up and down sporadically, but turning on the AC and fans would cause the rpms to drop and almost stall again. Turned it off for a while and then it started up fine and ran ok, but the engine light stayed on this time. So hopefully this will remain so they can get a code.Up until this happened the car worked fine except for occasional rpm and gear change when coasting on hill, but from I what read, this seems normal. Although, there was occasional very slight hesitation when hitting the gas after a stop light/sign.
Posted: Sat Jul 17, 2010 9:41 am
by Gil
The above happened for a second time today, so I decided the disconnect the battery to see if that would reset anything... Well, after reconnecting the battery if struggled to start once, stalled and now won't start at all. Looks like I'm going to have to get the F-ing thing towed to the dealership now.Also, when I reconnected the battery the park lights seemed to flash a couple times, not sure if this is normal?
Re: (Gil)
Posted: Sat Jul 17, 2010 9:51 pm
by keithvibe
Quote, originally posted by Gil »The above happened for a second time today, so I decided the disconnect the battery to see if that would reset anything... Well, after reconnecting the battery if struggled to start once, stalled and now won't start at all. Looks like I'm going to have to get the F-ing thing towed to the dealership now.Also, when I reconnected the battery the park lights seemed to flash a couple times, not sure if this is normal?Have you had the battery, alternator, and starter checked?I know I didn't mention how to disconnect the battery, but disconnecting the negative cable first then postive second is the correct way to do it.The parking lights shouldn't flash, unless you have a car alarm.
Posted: Sun Jul 18, 2010 10:59 pm
by Gil
Re: battery, alternator, and starter - haven't had them checked but the car is at the dealership now, so will see what they find.
Posted: Mon Jul 19, 2010 9:14 pm
by Gil
It was the PCM. Repaired under warranty!
Posted: Mon Jul 19, 2010 9:51 pm
by Wolfman213
Glad you got it taken care of, esp under warranty!
Re: (Wolfman213)
Posted: Tue Jul 20, 2010 2:55 am
by lovemyraffe
That makes sense. If the PCM is bad, it doesn't always throw a code. Glad you got it taken care of.
Re: (Gil)
Posted: Tue Jul 20, 2010 8:56 am
by star_deceiver
Nice that it was fixed for free!!!!
