Headlamp Lens
Posted: Fri Jul 09, 2010 1:45 pm
by Mo411
Can the Inside of the Headlamp be cleaned - seems that's where most of my distortion is.
Re: Headlamp Lens (Mo411)
Posted: Fri Jul 09, 2010 8:04 pm
by keithvibe
only if you bake it open
Re: Headlamp Lens (keithvibe)
Posted: Fri Jul 09, 2010 10:18 pm
by A Psycho Martyr
still too skurred to do anything with mine....
Posted: Thu Jul 29, 2010 11:59 am
by jd521
Try the Meguiars " TECHWAX" . About $19.00 a bottle. Seems to restore the lens in like new condition.
Re: (jd521)
Posted: Thu Jul 29, 2010 7:35 pm
by keithvibe
^^ he wants to clean the INSIDE of the headlight
Posted: Fri Jul 30, 2010 11:56 am
by Herb
Out of curiosity, if the lens has a small crack on the edge, could it be resealed?
Posted: Sun Aug 22, 2010 11:15 pm
by Vibe2.0
What is "Plastic X " ?
Re: Headlamp Lens (Vibe2.0)
Posted: Mon Aug 23, 2010 2:24 am
by A Psycho Martyr
Quote, originally posted by Vibe2.0 »What is "Plastic X " ?Meguiars PlastX (gets rid of cloudy plastic)
Posted: Mon Aug 23, 2010 8:30 am
by BrettZ
I can vouch for PlastX. Works like a charm. You may have to use a fine grit sand paper if the stains are etched in, then polish with PLastx. But for the most part PlastX does wonders on its own.I also polished my instrument panel cluster with it as well. You'd swear you could reach out and touch the speedo with nothing in between.
Re: (BrettZ)
Posted: Thu Aug 26, 2010 12:13 am
by Whelan
I am finding it hard to believe you have a problem with the inside of the lens as it is a sealed unit and should not have scuffing or markings. Typically all this occurs outside and some Meguiar's Plast X on a buff pad will work wonders.I use my Meg's G100 DA Orbital Polisher with a 8006 pad on Speed 5. Put the product on in a X pattern on the pad and go to work on the light. Sometimes 2 applications are necessary.If you run into the problem of the haze still being there, you may need more serious work. this will require several wet sand paper pieces ranging from very fine to fine. Start with the fine and go up to very fine working gently (it's not a piece of wood). Keeping the surface wet and the paper as well at all times and wiping with a rag constantly. Then once you are done with the very fine, move to a buff pad and use swirl/scratch remover on a buffer, then polish, then wax.
