No Tail lights/dash lights
Posted: Fri Jul 09, 2010 12:04 am
by 2hot
Hi I have a problem..I have no tail lights and no dash lights except the ones behind the speedo that stays on full bright no matter what the dimmer switch is set at..i have checked the fuses in the car and under the hood..all are good...any other suggestions?thanks
Re: No Tail lights/dash lights (2hot)
Posted: Fri Jul 09, 2010 12:12 am
by A Psycho Martyr
hmmm.... that's a pretty inconvenient problem I'm not the best with the electric stuff (other than running my own) so hang in there and someone will throw some suggestions at you.Is it your BRAKE lights that don't work? or just your RUNNING lights?And one time I had all my dash lights go out, but it was because my lil bro stuck a penny in the cig lighter but that blew a fuse and was an easy fix. Your problem seems more difficult.
Re: No Tail lights/dash lights (A Psycho Martyr)
Posted: Fri Jul 09, 2010 12:20 am
by 2hot
just the running lights as someone told me as i was getting off the highway the other night after midnight
Posted: Fri Jul 09, 2010 12:31 am
you didn't say what year Vibe you had, but if it's a 2003-2008, then see if the info in
http://forums.genvibe.com/zerothread?id=40528 helps
Re: No Tail lights/dash lights (joatmon)
Posted: Fri Jul 09, 2010 1:19 am
by 2hot
thanks for that thread...as soon as i pulled the glovebox out the relay dropped onto the floor..thanks again
