Engine and tranny swap?
Posted: Mon Jul 05, 2010 11:51 am
by jessep19
hey guys, I have a 2003 with the 1.8L VVT-I and i was thinking of swapping it with an other engine and manual tranny(so changing from auto to manual)? You guys have any engines and trannys ideas that would be good? Thanks!
Re: Engine and tranny swap? (jessep19)
Posted: Mon Jul 05, 2010 2:13 pm
by star_deceiver
The 2zz-ge and 6 speed from the GT would be a direct swap...
Re: Engine and tranny swap? (star_deceiver)
Posted: Tue Jul 06, 2010 7:08 am
by jessep19
I heard that it means that i have to change the computer and part of the center console and so on?
Posted: Wed Jul 07, 2010 9:11 am
by star_deceiver
Computer yes, but I don't see why the console would need too much reworking
Posted: Wed Jul 07, 2010 11:20 am
by jessep19
Thats just what i've been told anywase I will look into it and see what kind of deal i can get.
Posted: Thu Jul 08, 2010 6:58 pm
by SmAshley
Quote, originally posted by jessep19 »hey guys, I have a 2003 with the 1.8L VVT-I and i was thinking of swapping it with an other engine and manual tranny(so changing from auto to manual)? You guys have any engines and trannys ideas that would be good? Thanks!So you have an AUTO? If you have an auto then yes you will have to modify the centre console only to be able to house the new shifter assembly. But you will most likely be able to do this NP if you research it all first to ensure that you have all of the required parts/computers.My BF & i have completed similar swap with his GrandAm, Auto swap to manual. For this we required the following ;( this is what we needed, may or may not be required 4 VIBE )- 5spd Transmission - mounts - sub frame-Flywheel/clutch - master/slave cylinders - -shifter assembly with cables/linkage - Pedals- clutch & brake-ECU for manual tranny (matching year)All of the parts we got from a scrap yard and had a few "mickey mouses" with wiring the reverse lights and a neutral safety bypass but she works great. Hopefully this was helpful and good luck on your projectThe link below is from another member that has info on the engines that are "swapable"http://forums.genvibe.com/zerothread?id=40254
