Stupid question about brake light
Posted: Wed Jun 30, 2010 3:23 pm
by CaliManDan
Where is the best/easiest place to buy a bulb for a brake light for a 2003 Pontiac Vibe? And also how easy is it to change?
Posted: Wed Jun 30, 2010 9:11 pm
by Wolfman213
Any place that has the 7443 bulb. You're not going to find much of a price difference between an auto parts store vs mass market (i.e. Wal Mart). I haven't changed mine yet, but in trying to remember from other threads, I think you go through the little access doors in the rear panels.
Re: (Wolfman213)
Posted: Wed Jun 30, 2010 10:24 pm
by CaliManDan
So the part # is 7443? Is there a way I can check that myself for future reference? When I turn my headlights on, both of the rear brake lights light up, as they should. It's only when I actually press on the brake pedal that only one brake light gets brighter (as it should), while the other doesn't. So is that particular bulb still a 7443?
Posted: Wed Jun 30, 2010 11:08 pm
by WooTinn
The 7443 is a dual filament bulb, one with higher risistance and one with lower. Which creates the dimmer light and the brighter light modes.It's the same bulb for the running lights and the brake lights. Sometimes one filament will burn out and the other one will remain intact. Mine did the exact opposite of yours, and the brake lights worked but not the running lights.Mine came in a pack of two for just over 5 dollars with tax at an O'Rielly's.It extremely easy to change these out. Just pop your back hatch open, remove the cargo access panel to the side you're changing, and if you reach inside towards the lights, the one on the top is your 7443 brake light. Just twist it a little bit (counter-clockwise i believe?) and pull it out. The bulb will pull straight out of the socket and at this time you can replace it. To put it back in, just go backwards through these steps.Hope I was of some help!
Posted: Wed Jun 30, 2010 11:34 pm
by Wolfman213
Exterior Bulb ThreadIn case you ever need it, here's the Interior Bulb Thread.
Posted: Thu Jul 01, 2010 2:10 am
by ramenboy...
like these guys said. 7443. dual filament. easy to switch out. and yes, just open the plastic storage panels to get access to the break light assembly/bulbs.have fun!
