So0o i got a jetski and dunno if i should offer my vibe as its tugboat... can the base vibe transmission handle towin a 600lbs jetski?And wat kind of hitch is best?
-aBySS Monotone Vibe-Auto Everything (I wanted a manual)-Moons and Tunes-No Badges-No Lateral Bars-Sony CDX-M730 Head Unit-200w PPI Amp Powering a 12" MTX Sub-9 1/2'' Stainless Steel Trumpet Air Horn-Spare Bridgestone Blizzaks Mounted on the Cheapest Steel Rims Ever
ahh true.. jet ski's are the stand up type right... then i guess its a wave runnerWhere would a find a hitch that'll fit my vibe?
yea i know i remember seeing the posts but im searching for them and coming up empty
Nope. Draw-Tite. Installation info & pics: http://forums.genvibe.com/zerothread?id=784Wiring info & pics:http://forums.genvibe.com/zerothread?id=1139Very easy to put on. Not too bad to wire up either if you like to do that type of stuff yourself.A waverunner should be about 600lbs, trailer 200lbs +/-, so you should be able to haul it with no problem. May even come in under the 1500lb limit with two waverunners.....
