Why don't 5x100 fit????????????????????????????????????
Posted: Fri Jun 11, 2010 8:39 am
by tripped455
I have an `05 Vibe with the crappy steelies and the crappy caps. I bought a set of Konig 5x100 wheels that don't fit. I measured the bolt pattern and I have 5x95. Do I have a ******* car or is this common because I have not heard anything about this bolt pattern.Thanks
Re: Why don't 5x100 fit???????????????????????????????????? (tripped455)
Posted: Fri Jun 11, 2010 8:48 am
by BlueCrush
The Vibe is 5x100. Are you sure the wheels you got are also 5x100? If so there is no reason they should not fit. If they do not fit, then there is an issue with the wheels. I have had many different sets of wheels and the Vibe IS 5x100. I can guarantee you that.
Posted: Fri Jun 11, 2010 9:10 am
by tripped455
The one I have is not 5x100. The wheels say 5x100 on the back and I measured them as well. They are 5x100. The bolt pattern is 5x95 measured as well. Weird I know.
Posted: Fri Jun 11, 2010 9:11 am
by 06pvibe
If the pattern is too big (on the wheel) then they probably gave you 5x114.3 (4.5") instead of 5x100 (3.93") by mistake.
Re: (tripped455)
Posted: Fri Jun 11, 2010 9:12 am
by BlueCrush
Are you sure you have a Vibe?? lol. J/K.
Posted: Fri Jun 11, 2010 9:20 am
by tripped455
Pretty sure, work for Toyota and would only buy one!
Re: (tripped455)
Posted: Fri Jun 11, 2010 9:34 am
by lovemyraffe
Bolt pattern is 5 x 100. Like the others said, if the wheels don't fit, you didn't get 5 x 100 or maybe the previous owner made some weird changes.
Posted: Fri Jun 11, 2010 10:03 am
by tripped455
Ok, what is the proper way to measure bolt patterns. I am checking from center of stud to center, maybe that is wrong. These wheels maybe standard size wheels even though they are stamped metric.
Re: (tripped455)
Posted: Fri Jun 11, 2010 10:20 am
by 06pvibe
Re: (06pvibe)
Posted: Fri Jun 11, 2010 10:25 am
by Old Tele man
+1, I belive you've "nailed" his problem....MEASUREMENT technique on 5-bolt pattern hub.
Posted: Fri Jun 11, 2010 10:36 am
by tripped455
Well that clears up some things. Now to find out (removed) these fit so I can get rid of them.Thanks
Re: (tripped455)
Posted: Fri Jun 11, 2010 5:39 pm
by 06pvibe
You're welcome.And if what I suspect happened happened and you have 5x114.3's, one car they might fit is Mazda... assuming the offset is correct. Mazdas have a very deep negative offset.
Posted: Sun Jun 27, 2010 10:36 am
by rareorange1
I have never even heard of a 5x95 bolt pattern.
Posted: Sun Jun 27, 2010 12:26 pm
by DoubleBaril
is it for sure the bolts that are not lining up, or is it possibly the center bore is too small on the new rims?
Bolt Circle Measurement (5x)
Posted: Mon Jul 05, 2010 1:38 pm
by bpgmcbill
Another option for finding bolt circle for a five lug wheel: Measure the distance from bolt center to adjacent bolt center and divide by sine(36). That's pretty close to multiplying by 1.7.
