				Cargo Mat
				Posted: Wed Jun 09, 2010 4:44 am
				by 09vGT
				I have some rattling in the cargo area.. can't ever look while driving .. but If i got a carpeted cargo mat to put in the back would that cut down on some of the noise? Even road noise? Where's the cheapest place to buy one from?
				Re: Cargo Mat (09vGT)
				Posted: Wed Jun 09, 2010 5:01 am
				by lovemyraffe
				I got mine from the Home Depot for $6 or so and cut it to size.
				Posted: Wed Jun 09, 2010 5:11 am
				by ou.grizzly
				Our Black 09 squeaks back there and it is the cargo tray/lid deal - I need to take it apart and apply some strips of felt to keep the plastic from rubbing. I would suspect some of the rattling is some of the same items - but you are and and so is Raffe. A cargo mat is the best way to go and home depot stuff n cut it down to size is the most economical.
				Re: Cargo Mat (ou.grizzly)
				Posted: Wed Jun 09, 2010 5:18 am
				by jkm311
				I was also considering door stripping they sell at hardware stores. You know, the stuff that makes a tight seal when you close an exterior door in frame. A short/shallow height applied under the locking top/cargo floor may do it. Plus, the types I have used are in a gray color very similar to our plastic back there. Although, you would only see it when your spare tire area is open.
				Re: Cargo Mat (jkm311)
				Posted: Wed Jun 09, 2010 5:20 am
				by ou.grizzly
				Quote, originally posted by jkm311 »I was also considering door stripping they sell at hardware stores. You know, the stuff that makes a tight seal when you close an exterior door in frame. A short/shallow height applied under the locking top/cargo floor may do it. Plus, the types I have used are in a gray color very similar to our plastic back there. Although, you would only see it when your spare tire area is open. If I can swing coming to the Indy Meet, we can do a strip n' felt party...
				Posted: Wed Jun 09, 2010 5:34 am
				by jkm311
				Call the babysitter! This Meet is gettin' outta hand.
				Posted: Wed Jun 09, 2010 1:41 pm
				by Zimm
				i recently installed a rubber cargo mat in my '10.  it cut down on some of the noises i was getting back there.  and this is going to make me sound dumber than usually sound, but while installing the mat, i opened my spare tire hatch and discovered some cargo tie downs that i did not realize were in there since day 1.  90% of the clunking i heard in my car came from them bouncing around back there.  they're much quieter in place and tensioned in the cargo area!
				Posted: Thu Jun 17, 2010 9:02 am
				by lowincash
				I used to have some rattling squeeking noise in the back but after putting some carpeting there the noise went away and was never heard again.  I bought a roll of carpet from home depot and cut to fit and it works great
