Mr.Dyno???
Posted: Tue Jun 10, 2003 10:49 pm
by robdog
I know some of you have the Mr. Dyno. Just wondering how you like it and how it actually hooks to your car(Vibe). Also, does this work on any car. I would like to get one but just wanted some info on if it is worth it and how well you think it works and how it actually reads the info coming from the car. Thanks
Re: Mr.Dyno??? (robdog)
Posted: Thu Jun 19, 2003 12:57 am
by Space_Cowboy
Yeah, I was wondering if anyone has this product, or something like it and how it was working out. I really want to know how I'm doing in terms of performance, and something like this seems like the easiest and cheapest way of figuring that out....
Posted: Thu Jun 19, 2003 2:32 am
by meathead333
what is mr dyno?
Re: Mr.Dyno??? (meathead333)
Posted: Thu Jun 19, 2003 3:43 am
by Space_Cowboy
if you go to www.mrdyno.com it gives some product info, basically it's a meter to measure performance on your car and stuff like that...sort of like a mini-dyno...I was just wondering if these things are any good, or if they're junk and not worth the money...anyone have any experience?
Re: Mr.Dyno??? (Space_Cowboy)
Posted: Sat Jun 28, 2003 6:39 am
by satur9
i got one. you plug it into the lighter or it runs of batteries. you have to set it up for each different car you put it in but it does have four car presets. after the hassle of entering a whole lot of input data it works pretty good . i pulled a 16.5 which is around what a good base vibe would run and dynod at 121hp which is a little over 1hp more than injens baseline(real dyno) from their site .its great for the price but two things. you must use it on flat and level ground and you have to level the unit (tilt it up or down)or else readings will be screwy and you have to get use to the way words are shown on the screen. .
