Can 110 V and 12V outlets stay on with the ignition OFF?
Posted: Tue Jun 10, 2003 2:40 pm
by Strobo43
Does anyone know if we can change the 110 V and/or the accessory 12V outlets to stay on with the ignition OFF?My old Caravan had a relay to add into the fuse box that allowed one to have power on at ALL times.
Re: Can 110 V and 12V outlets stay on with the ignition OFF? (Strobo43)
Posted: Tue Jun 10, 2003 3:56 pm
The design calls for them to be disconnected when the power is cut to the car -- AFAIK, nobody has found a simple workaround for this yet, if any workaround has been found at all...
Re: Can 110 V and 12V outlets stay on with the ignition OFF? (ragingfish)
Posted: Thu Jun 12, 2003 7:23 am
by esjones
quote:The design calls for them to be disconnected when the power is cut to the car -- I wonder if the '04 models are wired the same way.
Re: Can 110 V and 12V outlets stay on with the ignition OFF? (esjones)
Posted: Thu Jun 12, 2003 9:39 am
by stkos79
theres a red/white wire off the power outlet switchif you run a fused 15 constant wire to it the unit willwork all the time but watch so you dont drain you batthopes this helps,,,
Re: Can 110 V and 12V outlets stay on with the ignition OFF? (stkos79)
Posted: Fri Jun 13, 2003 3:30 pm
by meathead333
quote:theres a red/white wire off the power outlet switchif you run a fused 15 constant wire to it the unit willwork all the time but watch so you dont drain you batthopes this helps,,,is that difficult, like will i kill myself? i miss that feature from my 2000 grand prix alot
Posted: Fri Jun 13, 2003 6:06 pm
by Strobo43
OK, I understand that about splicing in a HOT wire and fusing it. So where is a good place to hook into a hot wire without goint to the battery, or that the best?? Is there an easy way to run a wire from the fusebox that is already fused and on all the time?
Re: Can 110 V and 12V outlets stay on with the ignition OFF? (silverawd26)
Posted: Sat Jun 14, 2003 1:56 am
by Strobo43
What bigger size would fit our cars and do a good job?
