help on 05 s/c
Posted: Sun May 30, 2010 5:13 am
by flash
i have installed s/c on o5 vibe base. up to wiring ecu. any help would be highly appreciated.
Re: help on 05 s/c (flash)
Posted: Sun May 30, 2010 6:47 am
by BlueCrush
Great! Welcome to GenVibe!! Might help to list what issues you are having. You installing an EMB, EMU or AEM?
Re: help on 05 s/c (BlueCrush)
Posted: Sun May 30, 2010 3:40 pm
by flash
i installed GM s/c kit 12498927. during install realized the kit is for 04 throttle body. mine has no cables; so, i got an adapter to keep original tb.ran engine to ckeck for leaks, none noted. began wiring fifth injector and saw that no other wiring match my car or the instuctions for the 04. i'm not sure if i can use larger injectors and have the car remaped, or if i have to use the s/c ecu.if the latter, then i need to know what wires go where. if i had a good schematic, i beleive i could re pin all the connectors. but holy crap. i'd love to find the right wire harness and just plug it in and go.thank youflash
Posted: Mon May 31, 2010 12:18 am
by BlueCrush
If you have an '05+ vibe and are using the S/C, you will need to dump the 5th injector run with 2ZZ injectors and us an EMB, EMU or AEM piggyback to control the fuel and timing.
Posted: Wed Jun 02, 2010 1:44 am
by flash
can you send me a parts list, what ever you recomend. i'm getting no talking to the technitians. they say i have to choose. if only i knew enough about all this, i would. please tell me the simplist setup. oh, injectors...there appears to be more than one 05 2zz motor. i don't know what to get.
Posted: Thu Jun 10, 2010 2:18 pm
by flash
thanks bluecrush. i've installed the 2zz injectors. already better. now i'm waiting for the tuner to help narrow down witch fuel controler to get. i'm under the impression that once it's in, i'll have to get it mapped and tuned. let me know if can get one premapped and not have to tune and dyno please. again, thanks for the help. i've always dealt with big older cars, so the newer stuff is ruff going.
Posted: Sat Nov 27, 2010 10:04 pm
by rollavvti06
good choice on the 2zz injectors im running the e mange blue on my super charger cause its the cheaper one and i can send you a base map to run it
Re: (rollavvti06)
Posted: Mon Nov 29, 2010 2:43 pm
by flash
that's the best news i've gotten in weeks. the map will get things rolling again. let me know what you need from me. i'm not sure how you'll send it.
