break boster cable to inject sea foam
Posted: Sat May 22, 2010 10:18 am
by oriden
I just picked up some sea foam today, i have inserted some into the crank case and the gas tank,can some one confirm the location of the so called "break boster" hose to funnel the seamfoam into the chambers?thanks!
Posted: Thu May 27, 2010 11:28 am
by Mark
Did you ever figure this out? The booster is on the right hand (drivers side) of the engine compartment, on the firewall right behind the master cylinder. There is a valve on the front of the booster, just to the left of the cylinder. The hose attached to that valve is the one you want.
Re: (Mark)
Posted: Fri May 28, 2010 11:21 am
by oriden
yeah i figured it out before hand i just wanted to make sure.thank you to the one person that actuly posted..
