Truck bed coating on grey body cladding?
Posted: Fri May 21, 2010 12:10 pm
by mmendez72
Any one ever tried it before?. I used bumper spray coating and it worked good but it eventually chipped off. I was thinking about using a rubber spray or truck bed coating or whats called a underpanel spray thats rubberized.......
Re: Truck bed coating on grey body cladding? (mmendez72)
Posted: Mon May 24, 2010 11:12 pm
by vibolista
Holy cow, sorry no one jumped on this for you... so I'll give it a shot! There was a posting last year about one of the forum members using some type/brand of Rhino Coat or other in the back of his Vibe. You can do a search for the particular thread on this forum if you want. I can't see why you can't coat the back plastic load area with something like Rhino lining paint/platic or what ever it is. It's a really tough product and holds up great. I'm not pushing Rhino stuff... it's just the only brand name that I can remember right now. Most of these type of products now come more colors than just black, so you could end up with a less industrial "look" back there. Not sure about a rubber product, but there might be. I'm using an industrial type rubber mat 4'X6' that keeps stuff from sliding around and also helps keep the scratches gouges away. Home Depot... about 30 bucks or so. Let us know what you end up doing!
Re: Truck bed coating on grey body cladding? (vibolista)
Posted: Mon May 24, 2010 11:53 pm
by Wolfman213
Quote, originally posted by vibolista »There was a posting last year about one of the forum members using some type/brand of Rhino Coat or other in the back of his Vibe. That'd be me! Check out my garage and you can see the pics of it or, better yet, Click Here I used Herculiner and it's held up really well. There have been some places where bc of what I've thrown or placed in there that it's "chipped" or "torn" a little, but you can always go back over it since due to the nature of the bonding. Those spots may look a little shinier BUT since you are dealing with the outside of the Vibe, chances are you won't be throwing stuff on there to cause any issues.
Re: Truck bed coating on grey body cladding? (Wolfman213)
Posted: Tue May 25, 2010 12:49 am
by bodhi_tree777
I think he's asking about the exterior plastic cladding?
Posted: Tue May 25, 2010 1:11 am
by Wolfman213
If it's made of the same as the interior plastic, the outcome should be the same. I just wanted him to know my experience from the interior. Since the exterior won't be getting the abuse that I've put on the interior, shouldn't have any probs.
Posted: Tue May 25, 2010 2:50 am
by mmendez72
Ill have to look into the rhino coating. The spray worked pretty good but after a few dings it began to chip off....
Posted: Tue May 25, 2010 3:56 am
by Wolfman213
With it being on the outside, make sure you use something to remove and wax or other cleaning stuff that may have built up over time.
Re: Truck bed coating on grey body cladding? (bodhi_tree777)
Posted: Wed May 26, 2010 3:20 am
by vibolista
Yah, I should have stated that the plastic cladding outside would probably accept the Rhino Coat. Was using inside plastic load deck as example of the holding power of the product... as it tunrned out... on Wolfman's Vibe.
