Toyota Matrix fuel door compatible with Pontiac Vibe?
Posted: Thu May 13, 2010 12:00 am
by hawksdman35
Hey all! This is my first post. Anyways, I have an 04 VIbe, and my fuel door was ripped off by a dumb gas man Pontiac wants 95.00 for a new fuel door not painted! But Toyota only wants 60.00. The guy is very hesitant to sell it to me, because hes not sure if it would be compatible or not. What is your input on this guys? Can anyone help me? My Vibe looks like a mess with out the fuel door!
Re: Toyota Matrix fuel door compatible with Pontiac Vibe? (hawksdman35)
Posted: Thu May 13, 2010 4:57 am
by zionzr2
there is quite a bit of sheet metal differences in the vibe and matrix, so my initial response would be I doubt they are compatible. You might try a junk/salvage yard in your area to see if there is an available fuel door for a vibe.
Posted: Thu May 13, 2010 7:54 am
by Bikerscum
http://www.uneedapart.com/$40 used in silver. Lots of used parts search services online.
Posted: Thu Oct 18, 2012 7:49 am
by CMH
I need a 2003 Vibe fuel door and hinge. Searched gm parts and found only springs or whole quarter panel (over $100). Fuel door hinge broken in gas theft, door lost on road. Has anyone replaced a door and hinge, and where did you get it?
Posted: Thu Oct 18, 2012 6:03 pm
by Flip-Side
Mounting is identical, shape and clearances are totally wrong.
I got mine from a junk yard. I drilled out the rivets of the mount still stuck to my car, threw it away, and riveted the new one on. Paint did not match, so a body shop sprayed it for me for a fee. Better to get one that matches to save money.
The gas doors on the 2003 vibes are known to break, the cheap rolled steel hinge seizes and breaks if it never gets lubed. Most likely not the gas guys fault. I use white lithium grease on my newly acquired matrix to prevent it from happening again. Any autoparts store will have it.
