Supercharger boost guage
Posted: Sat May 08, 2010 3:08 am
by cagarcia14
This may be a stupid question but, can you hook up a boost guage to a supercharger? I'm new to the whole FI idea.
Re: Supercharger boost guage (cagarcia14)
Posted: Sat May 08, 2010 3:53 am
by keithvibe
not only should you have one, you shouldn't drive one with out it.Start here:http://matrixowners.com/index.php?showt ... sh...unt=1
Re: Supercharger boost guage (keithvibe)
Posted: Sat May 08, 2010 4:44 am
by cagarcia14
After you showed me those links i was thinkin bout buying this: http://www.yourhotcar.com/prod...48977/But, I have two questions.If I bought this what else would I need to do to the engine to ensure that it won't blow up?And, if I could use this on my 03' automatic vibe?
Posted: Sat May 08, 2010 5:13 am
by keithvibe
Quote, originally posted by cagarcia14 »After you showed me those links i was thinkin bout buying this: http://www.yourhotcar.com/prod...48977/But, I have two questions.If I bought this what else would I need to do to the engine to ensure that it won't blow up?And, if I could use this on my 03' automatic vibe?you would need some sort of engine management. Emanage blue, Emanange Ultimate ect.Guages, some sort of boost controller.That is a basic universal kit. That will require lots of fittment adjustment. It's not going to be a bolt up and done.Then you will need someone to tune it so it don't go BANG.Tuning will be key, add another 500.00 to 1000.00 for tuning.I doubt that intercooler will fit behind the front bumper brace IMO. Your going to need to know someone who can weld as well.You will also most likely need to have the trans upgraded depending on your boost level.http://www.levelten.com/Search...ted=YBefore you decide to undergo this I suggest you read this thread.http://matrixowners.com/index.php?showtopic=63187It will show you if you don't have much knowledge and take it to shops that don't have a clue what they are doing your simple build could turn in to a nightmare.
