Installed new Headunit, now no sound
Posted: Thu Apr 29, 2010 2:09 pm
by AdmRose
I installed a new JVC headunit (JVC-KD-HDR20) and now none of my speakers work. I accounted for all the speakers when I was splicing the wires but Crutchfield didn't send me anything for the 2nd plug I pulled out of the rear of my radio (8 hole black plug with four wires in it). My questions are:1) What is that plug for?2) Could it have any bearing on my speakers not working?I have the six speaker setup in a 2004 Vibe. Any help would be appreciated.
Re: Installed new Headunit, now no sound (AdmRose)
Posted: Thu Apr 29, 2010 2:24 pm
by Toasted7
Is that a moon & tunes package?Take a look at the first sticky'd post about the Moon & Tunes Aftermarket HU install. That helped me fix my problem when I put an aftermarket HU in my 2005.
Posted: Thu Apr 29, 2010 3:58 pm
by AdmRose
I'm honestly not sure if it is or not. How do I tell?
Re: (AdmRose)
Posted: Thu Apr 29, 2010 7:40 pm
by keithvibe
do you have a sub woofer in the rear cargo area?
Re: (keithvibe)
Posted: Fri Apr 30, 2010 1:34 am
by AdmRose
I do not.
Re: (AdmRose)
Posted: Fri Apr 30, 2010 1:41 am
by Toasted7
I don't think they added the moon & tunes package (with sub) till '05... so the post I was talking about earlier might not help you out like I thought. Sorry
Posted: Fri Apr 30, 2010 5:11 am
by AdmRose
Well I found I do have the amp under the seat.
Posted: Fri Apr 30, 2010 5:12 am
Quote, originally posted by AdmRose »I have the six speaker setup in a 2004 Vibe. Any help would be appreciated.six speakers in a 2004 Vibe = Moon & Tunes packageMoon& Tunes gives you- Sunroof- Tweeters in the front door by the mirrors- amplifier under the front passenger seatOne possible cause for no sound is that in hooking up the new headunit, you did not provide the remote turn on signal for the amplifier. The radio drives the amp, the amp drives the speakers. I don't remember which wire is amp turn on, but perhaps the info in
http://forums.genvibe.com/zerothread?id=31372 or
http://forums.genvibe.com/zero...o.gif will help you identify it.That's one possible cause, there's got to be others.
Re: Installed new Headunit, now no sound (joatmon)
Posted: Fri Apr 30, 2010 5:13 am
by AdmRose
I'm pretty sure that it is. Just have to find out how to connect them. The new head unit did come with the remote wiring just need to find out where to hook it into on.
Posted: Fri Apr 30, 2010 6:00 am
by keithvibe
your going to need a line conversion.PAC-OEM or Scoschesee the sticky at the top of this page.BTW:the second plug that is left behind from the aftermarket HU install isn't used. No need to worry about it.
Posted: Fri Apr 30, 2010 8:50 am
by AdmRose
The new headunit has a blue/white remote lead wire, do I still need a line conversion?
Re: (AdmRose)
Posted: Fri Apr 30, 2010 8:19 pm
Quote, originally posted by AdmRose »The new headunit has a blue/white remote lead wire, do I still need a line conversion?Its two separate things.The amp turn on signal is one.Completely independent, people have found that aftermarket headunits need an audio line level converter inline between the headunit and the amp. I forget the details, something like the new HU overdrives the amp input, resulting in distorted audio.
Posted: Sat May 01, 2010 10:53 am
by AdmRose
Problem fixed. The Crutchfield harness didn't have the amp remote wire but they did include a loose red wire which I just inserted into the harness at the #15 spot and after crimping presto - everything worked. I did get the hissing sound at zero volume but the HU has adjustable amp output and I set it to low - the hiss is still there but it's ok for me.
