Rear Seat Removal
Posted: Sat Apr 24, 2010 6:15 am
by Wolfman213
How do I remove the rear seats? I've got somethings I'm wanting to do to them and would like to get them out of the Vibe and into the basement. I have no problem just jumping into it and figuring it out on my own, but I know that they are some members that have removed them completed before so figured I'd just go ahead and ask.Thanks in advance!
Re: Rear Seat Removal (Wolfman213)
Posted: Sat Apr 24, 2010 8:29 am
by BlueCrush
That is exactly what I did when I put in the Fatmat. I just started locating and pulling bolts until I felt that they were all out. I was easy getting the seat out, it was a ***** to get it back in due to the bulk, weight and trying to align everything by myself. I will be easier if you remove everything from the cargo area, lids, trays, etc so you can get a the bolts from the rear. Teh front seats were a breeze compared to the rear (for me). Take pics, if you can, of the process and document it if you have time. Good luck!
Posted: Sat Apr 24, 2010 9:16 am
by waveresponder
first slide front seats as far foward as they can goremove headrests on rear seatsnext fold down rear seats towards bottom on each side of seat plastic rear cover there is a small plastic cover thats part of the larger overall cover (square or rectangle in size) you have to remove the smaller covers to gain access to the bolts to remove the top sections of the seats, remove by prying with screwdriver carefully, remove bolts once you get the top portions of the seats removed you should be able to easily see what else needs to be done for the seats to be removed, dont forget to keep track of all you remove and where it goesJust did leather seat install on my vibe so I can pretty much answer any questions you may have.
Posted: Sun Apr 25, 2010 11:01 pm
by Wolfman213
Thanks for the replies guys. If I run into any issues, I'll be contacting you Wave. I forgot about those little pieces on the back of the seats giving access to bolts. I'll try and take pics and document the process for a small little write up.
Re: (Wolfman213)
Posted: Tue Apr 05, 2011 6:32 am
by A Psycho Martyr
sooooo......no write up?
Posted: Tue Apr 05, 2011 12:24 pm
by audiovibe
Wave hit it all but I will add that when I removed mine I put all the bolts back in the hole they were in so I didn't lose any.
Re: (A Psycho Martyr)
Posted: Wed Apr 06, 2011 1:06 am
by Wolfman213
Quote, originally posted by A Psycho Martyr »sooooo......no write up? had I done a write up, it would have been NOWHERE near as good as yours!!! Mainly, I simply forgot Killer write up you done for stripping everything Psycho!!
