How To Put A Lip Under The Front Bumper For Only $15
Posted: Fri Apr 23, 2010 7:42 am
by A Psycho Martyr
Ok I saw this idea on some other cars but never thought of doing it until I saw it on the Midnightunerz Vibe. I google'd it and found out it was extremely cheap and easy. Here's what you need... Weather strip for a garage door. I got the 15ft pack at Lowe's. You can get plastic or foam, but the foam is best, as it bends should you scrub your bumper.3m double sided tape. Try to find black so it matches your strip and won't show as bad.You can cut this stuff with scissors easily, so no tool is required. And you'll need some screws with washers on them to help hold it on. Something like this..Your first step is to apply your 3m tape on the back of the strip. Space it out unless you bought two packs. It won't cover the whole thing.When you get tape on the back of it, start putting it in place across the bottom of your bumper. Peel the backing off the tape as you go. The tape will hold, but for it to really last, you need to put some screws in it. I put six in mine evenly spaced.BEFORE!!!AFTER!!!Hope I covered everything. If you have any questions feel free to ask.
Re: How To Put A Lip Under The Front Bumper For Only $15 (A Psycho Martyr)
Posted: Fri Apr 23, 2010 8:25 am
by victorhasheart
That's beautiful! How did you screw them on? Also, you think tthe same can be done for the sides and the rear?
Re: How To Put A Lip Under The Front Bumper For Only $15 (victorhasheart)
Posted: Fri Apr 23, 2010 11:45 am
by A Psycho Martyr
little more difficult on the rear as there is no curvature to the bottom of the rear bumper. The front turns back in and the back just goes down and ends. The sides are doable, but may need some kind of "L" brace or something to keep the shape uniform through the whole side. Not needed in the front because the curve pulls it in. And when you look unser you'll see where to screw it in. Just barely have enough room to do it there
Posted: Fri Apr 23, 2010 2:32 pm
by 06pvibe
Ah! The ole' Home Depot GV lipThe Mazda community has been doing this for a number of years now.It would look a lot better if you used some tire shine on it. That'll make it look blacker as well as shinier.
Re: (06pvibe)
Posted: Fri Apr 23, 2010 10:03 pm
by A Psycho Martyr
Quote, originally posted by 06pvibe »It would look a lot better if you used some tire shine on it. That'll make it look blacker as well as shinier.Thanks for the heads up!
Posted: Mon Apr 26, 2010 5:58 am
by Kincaid
I'm really impressed at how well that turned out. Looks great! I've been wanting a front lip too.Also, I need to get one on my actual garage door, because I have some gaps that I think are letting mice in.
Re: (06pvibe)
Posted: Mon Apr 26, 2010 6:08 am
by BlueCrush
Quote, originally posted by 06pvibe »Ah! The ole' Home Depot GV lipThe Mazda community has been doing this for a number of years now.Yup. I remember seeing a thread about this here on Genvibe a couple years ago. Someone else on here did it as well. Turned out decent.
Re: (Kincaid)
Posted: Mon Apr 26, 2010 7:10 am
by A Psycho Martyr
Quote, originally posted by Kincaid »Also, I need to get one on my actual garage door, because I have some gaps that I think are letting mice in. Glad this could serve as a reminder! Mine only cost like 9 bucks
Re: (A Psycho Martyr)
Posted: Mon Apr 26, 2010 11:15 am
by vibolista
Excellent! Looks really good. How many screws did you use? Wouldn't it be better to use bolts instead of screws? Any reason you didn't do a continuous strip of double sided tape on it, instead of sections?
Re: (vibolista)
Posted: Mon Apr 26, 2010 11:44 am
by A Psycho Martyr
Quote, originally posted by vibolista »Excellent! Looks really good. How many screws did you use? Wouldn't it be better to use bolts instead of screws? Any reason you didn't do a continuous strip of double sided tape on it, instead of sections? Thanks, and good questions I used six screws evenly spaced. It might be better to use bolts, but I didn't have any, so screws with wide washers to give them some suface area is what I used. And I only bought one roll of 3m tape and it wasn't long enough, so I spread it out instead of going back to town.
Posted: Tue Apr 27, 2010 8:32 am
by Houston
Looks fine, but I wonder if the material is strong enough to hold its shape when on the expressway.
Re: How To Put A Lip Under The Front Bumper For Only $15 (Houston)
Posted: Tue Apr 27, 2010 11:00 am
by A Psycho Martyr
Ill have to perform a field test. When my brother is free i'll have him ride beside my doin 70-80 and we'll see how it looks
Posted: Tue Apr 27, 2010 11:17 am
by star_deceiver
What will happen to the tape when it gets really hot out? Hope it doesn't sag...
Posted: Wed Apr 28, 2010 2:33 am
by houseofbugs
That actually looks really cool. I am going to do this once I get my stereo all fixed. It should look even better on mine as I have the grey plastic cladding around on mine.
Re: (houseofbugs)
Posted: Wed Apr 28, 2010 2:47 am
by A Psycho Martyr
true true
Posted: Thu Apr 29, 2010 11:12 am
by vibolista
There's always Frost White paint. Hint...
Posted: Thu Mar 03, 2011 12:57 am
by jscherf92
Im gonna try this over spring break next week, for such a low cost mod its certainly worth a shot. Hopefully it will give me a nice sideskirt look because buying the graphite side skirts AND my H.techs might start scraping over bumps
Re: (jscherf92)
Posted: Thu Mar 03, 2011 1:26 am
by A Psycho Martyr
Everyone who's done it so far loves it
Posted: Thu Mar 03, 2011 3:36 am
by Water boy
Quote, originally posted by A Psycho Martyr »Ill have to perform a field test. When my brother is free i'll have him ride beside me doin 70-80 and we'll see how it looks Is ya brother gonna hang out da winda to take cellphone pics or will he be in anuda car?
Posted: Wed Apr 13, 2011 3:52 am
by DjGodspeed89
Mine turned out great. Although it shows up a little better on your white. Check it out. Really the best pic I have of it now. But it really is an awesome mod considering they dont make a lip that I know of. It stays in place even at high way speeds. Thanks for the idea!!
Re: How To Put A Lip Under The Front Bumper For Only $15 (DjGodspeed89)
Posted: Wed Apr 13, 2011 4:10 am
by A Psycho Martyr
looks greatAnd glad this thread could help you out,But the credit for the idea goes out to ARCSvibe 8)I just did the write-up
Posted: Wed Apr 13, 2011 9:05 am
by DjGodspeed89
Just a couple more pics to add to Martyr's pics to say everyone should do this. If you're into that type of thing...
Posted: Mon Sep 12, 2011 3:26 pm
by A Psycho Martyr
Bump for new members....and I can't friggin BELEIVE how dark my h/l's and fogs were tintedcan't beleive you guys let me DO that.lol
Posted: Fri Oct 28, 2011 8:19 am
by Persephone
Definitely doing this.
Re: (Persephone)
Posted: Fri Oct 28, 2011 9:49 am
by A Psycho Martyr
Cheap...Easy...Looks amazing...Durable...The list goes on
Posted: Fri Oct 28, 2011 10:16 am
by 06pvibe
He is correct!!I put one on my lowered (-1.25") Mazda3 HB a few years ago and have scrapped it several times. But you wouldn't even know it to look at it.What was that old Timex commercial: Takes a licking and keeps on ticking....
Posted: Wed Oct 03, 2012 5:55 pm
by alpa109
HEy i have a pontiac vibe and im trying to do something with the grill.....where did u get that material and what is it called that u put over ur original grill
Posted: Wed Oct 03, 2012 6:15 pm
by A Psycho Martyr
A Psycho Martyr wrote:Mr. Grille was who I bought mine from on eBAY.
I guess they just have their own site now
HERE'S a link to the page
Posted: Wed Oct 03, 2012 10:46 pm
by thebarber
lol, why is this a popular mod for EVERY car now? seems soooo ghetto to me
Posted: Wed Oct 03, 2012 11:58 pm
by lannvouivre
Have you considered using plastic clips instead of metal screws? I mean, I don't know if the screws might damage that part of the front bumper or not, but all the places I noticed where metal screws were used on plastic trim places (when I was doing the wheel-well liner) had lots of layering around the screw (to prevent tearing, I'm guessing).
Posted: Thu Oct 04, 2012 9:11 am
by alpa109
thanks man but how do i find out if they have them for 2009....my years sucks i looked everywhere for stuff to do that car and i cant find anything for that year
Posted: Thu Oct 04, 2012 1:38 pm
by FootScoot
That's a great idea. I may go a different route, and put carbon fiber splitters on mine. They just mount underneath the front bumper with screws.
Posted: Thu Oct 04, 2012 2:20 pm
by KITT222
FootScoot wrote:That's a great idea. I may go a different route, and put carbon fiber splitters on mine. They just mount underneath the front bumper with screws.
That would be neat. Then it could evolve into a full bellypan.
alpa109 wrote:thanks man but how do i find out if they have them for 2009....my years sucks i looked everywhere for stuff to do that car and i cant find anything for that year
It's just garage door seal, you could apply it to any car.
