sounds like a ball peen hammer trying to get out of motor
cjdadman1
Post by cjdadman1 »
I got an 03 vibe that has a noise like someone is tring to beat thier way out of motor with a ball peen hammer? has any body got any ideas? Ihave looked to see if I can see a collapsed lifter but not sur is solid or hydralic in there . It almost looks like they are solid but cant tell and not ready to tackle the head bolts yet. i could really use the help please?
cptnsolo77
Re: sounds like a ball peen hammer trying to get out of motor (cjdadman1)
Post by cptnsolo77 »
Have you checked your oil level? How many miles?
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
djkeev
Post by djkeev »
Tell us when it happens, sitting in the drive idling?On hard Acceleration?Normal cruising?Down Hill?Up Hills?First started in the morning?After it warmed up?I also assume 1.8 engine?If so, they are solid lifters and adjusted by shims under the dics where the cam hits when it rotates, not easy to adjust but easy to check.Dave
(o ! /o) (o)=I=(o)
cjdadman1
Re: sounds like a ball peen hammer trying to get out of motor (djkeev)
Post by cjdadman1 »
to answer your questions the noise is so lud that you cant drive it . It happens all the time . I had a guy come over and look at it . he is a gm mech and took one listen and said that is s rod. now when we look at the oil you can see metal flakes in it . not good ! new motor time. eeven a good ud one is ing t run big bucks.
