XM Radio
Posted: Fri Jun 06, 2003 3:01 am
by yank dini
So last year right before my personal episodes with my old Vibe I was planning on getting XM radio. Now that the worst is over I was thinking about get one again. The problem is now I have the factory radio "that will stay in the vehicle for now" instead of my last radio that was XM ready. I need a good spot to put the receiver Anybody got a good spot for installing the receiver inside the car?
Re: XM Radio (silverawd26)
Posted: Fri Jun 06, 2003 3:24 am
by yank dini
ummm.... I dont think that will work I have to change the stations you knowhere is a linkhttp://www.xmradio.com/images/offers/summer_rebate.jpg
Posted: Fri Jun 06, 2003 3:30 am
by yank dini
yeah now I know that the black box will go under the seat but the display box is what im concerned with. The good news is that it has a red display like the gauges.
Posted: Fri Jun 06, 2003 3:33 am
by yank dini
yeah looks a lot better than last years model
Re: XM Radio
Posted: Fri Jun 06, 2003 3:39 am
That control head is about 1.5" x 4.3", about an inch wider than a creadit card. You should be able to find somewhere to put without too much trouble. Will you go with the FM modulator to tie it in, or do you have a secret you're not sharing?
Re: XM Radio (joatmon)
Posted: Fri Jun 06, 2003 3:53 am
by yank dini
quote:That control head is about 1.5" x 4.3", about an inch wider than a creadit card. You should be able to find somewhere to put without too much trouble. Will you go with the FM modulator to tie it in, or do you have a secret you're not sharing?I didn't know it was that smallI haven't been in circuit city roadshop in a while so I haven't seen them in person. If this is the case then right over the dummy would suffice.
by rasermon
Silverawd26, That looks like a good place to mount it.
Re: XM Radio (yank dini)
Posted: Fri Jun 06, 2003 4:47 am
by meathead333
anyone know about sirus?? is it the same set up and so fourth? my deck is supposedly pre set up for sirus. i am thinking about it. sorry, didnt mean to change the topic.
Re: XM Radio (meathead333)
Posted: Fri Jun 06, 2003 4:54 am
by yank dini
you get less channels on Sirrus but I think it's cheaper per month
Posted: Fri Jun 06, 2003 5:08 am
by yank dini
Is that for the XM?
Posted: Fri Jun 06, 2003 5:27 am
by yank dini
looks good
Posted: Fri Jun 06, 2003 5:36 am
by yank dini
is that even possible to remove the button without cracking the dash
Posted: Fri Jun 06, 2003 5:50 am
by yank dini
sweet
Posted: Fri Jun 06, 2003 5:52 am
by yank dini
well If it gets tight for me I can always downgrade my Comcast Digital Cable. I've had every channel possible since Dec last year ($150.00)
Posted: Fri Jun 06, 2003 6:37 am
quote:I didn't know it was that smallI couldn't tell from the picture that you linked, but whatever site it was on had a PDF owners manual that had some physical dimensions toward the back. (and an install guide)When I took off that bezel around the radio, it looked like the AC/Recirc controls were one assembly, and maybe the dummy button is part of that assembly. Might be you need to take that asembly off the bezel, and maybe the dummy button will come off easily. If not, there's always the dremel tool
Posted: Fri Jun 06, 2003 6:43 am
by Sub-Vibe-R
quote:You still can not see it too much, but the wiring to the left of the picture is attached to the recirculate and AC buttons. So, I am sure there is a way to take that "dummy button" off. In fact, you cannot just "remove" this dummy button. It is molded in the board. So you'll have to sand/cut, whatever you want, to make it flush to the rest of the board. It will be a permanant job.
Re: XM Radio (Sub-Vibe-R)
Posted: Fri Jun 06, 2003 6:47 am
I know it's getting a bit off topic, but did anyone ever hear a reasonable explanation of why they put the dummy button there in the first place?
Posted: Fri Jun 06, 2003 12:47 pm
by KSNeptune
quote:I know it's getting a bit off topic, but did anyone ever hear a reasonable explanation of why they put the dummy button there in the first place?Only the original dash designer can tell you for sure, but since I'm a product designer I'll give you my guess...Mocking up the center console, they had to lay out all the buttons/controls. There was plenty of space for the AC and Recirculate buttons left of the radio opening, so they put them there. But with only two to fill up the area, they were too far apart to seem related like they are. They tried moving them together, and they looked better, but it left an empty space which didn't balance with the overall look. They popped on a third button, and really liked how it looked there, balancing the design. They asked the engineers if there was some other A/C related "feature" they could control with that third button, but no one came up with an idea. The design team eventually had to show the upper execs their dash design ideas, and so they left it up to the execs... "Do you like it (the look) well enough with just two buttons? We (designers) think it would look better with three, but have no practical justification for a third button." The exec replied: "We don't have a reputation for justifying everything we do here as practical, so why should we start now? I say include the third button, and have it do nothing. It just looks much better that way."Now you have what might be a reasonable explanation. You can choose to believe it or disregard it. But it coulda happened that way! I've witnessed and participated in hundreds of design conversations that have resulted in purely aesthetic solutions over simple practicality.KSNeptune
Posted: Fri Jun 06, 2003 2:17 pm
by Savoy
I have my xm display installed in that little cubby hole under the glass hatch release button. It fits perfectly and no wires are seen. It's nice to flip up out of sight. It is not nice that I have to take my eyes off the road to look at it . I'm used to it now so that I can change channels without looking. I'll get a pic of it if anyone wants to see.-Savoy-
