Cleaning Machined Wheel Lip
Posted: Fri Apr 02, 2010 4:55 am
by BlueCrush
I need to clean the silver machined lip on my Hot Wheels. There is some rust and a minor pitting also the clear coat is flaking in some spots on the lip. What would be the best way to clean them up as much as possible? I know they won't be perfect but I would like to at least get the rust off of them so they look halfway decent. Any suggestions would be appreciated. Thanks! Here is a pic from when I bought them (used):
Re: Cleaning Machined Wheel Lip (BlueCrush)
Posted: Fri Apr 02, 2010 7:02 am
by KNINE
I really like that wheel design. I think most aftermarket wheels are tacky, but those look really good. I have no idea how to clean them.
Re: Cleaning Machined Wheel Lip (K-NINE)
Posted: Sat Apr 03, 2010 3:06 am
by BlueCrush
Thanks...lol. Anyone have tips or tricks to cleaning the lip?
Posted: Sat Apr 03, 2010 10:15 am
by 06pvibe
May I suggest a call to the Tire Rack to see what their people have to say about it?They might have just such an aluminum polish/cleaner that will do what you want. But then of course you will have to consider having them professionally refinished. Anything you do with a rattle can is liable to look like crap and/or allow infiltration beneath it which will only start the cycle all over again. At least a professional refinisher should offer a warranty against further damage... for a time.Nothing is forever... especially where cars are concerned.BTW: Those are some good lookin' wheels ya' got ther'.
Posted: Sat Apr 03, 2010 11:33 am
by ramenboy...
hey brian. yeah those are suweet looking wheels.i've heard aluminum foil really cleans chrome. not sure what 'machined lip' is but you could maybe try using a clay bar? it picks up the little grit on the body paint and leaves it smooth... maybe it will work on the wheels. i took a wire brush to mine last year and just today. not sure if you'd want too.'good luck
Re: Cleaning Machined Wheel Lip (06pvibe)
Posted: Sat Apr 03, 2010 12:15 pm
by BlueCrush
Quote, originally posted by 06pvibe »May I suggest a call to the Tire Rack to see what their people have to say about it?They might have just such an aluminum polish/cleaner that will do what you want. But then of course you will have to consider having them professionally refinished. Anything you do with a rattle can is liable to look like crap and/or allow infiltration beneath it which will only start the cycle all over again. At least a professional refinisher should offer a warranty against further damage... for a time.Nothing is forever... especially where cars are concerned.BTW: Those are some good lookin' wheels ya' got ther'. Thanks, I was thinking of some sort of polish, just not sure if I should use abrasive or non abrasive. Quote, originally posted by ramenboy... »hey brian. yeah those are suweet looking wheels.i've heard aluminum foil really cleans chrome. not sure what 'machined lip' is but you could maybe try using a clay bar? it picks up the little grit on the body paint and leaves it smooth... maybe it will work on the wheels. i took a wire brush to mine last year and just today. not sure if you'd want too.'good luckThanks, I don't think I would go as far as a wire brush but I was considering steel wool if a non-abrasive or abrasive polish didn't do the job.....? I think I'm going to wait for more feedback before doing anything.
Posted: Sat Apr 03, 2010 12:52 pm
by chevelle_lover
The clear coat on wheels will not stand up to anything that you have to scrub. ie steel wool Your best bet is to take them off the car and clean them on the bench with a good wheel cleaner and a childs tooth brush. Some scratch fix and wax may help. The clear coat on the wheels is similar to that on your car. If they are to bad for you, you may have to consider getting them re-cleared. The guy that I have gone to charges about $60.00 per wheel and he cleans all of the old clear off. If you want to try touching up the clear SEM makes a wheel clear that I have used in the past with decent results.
Posted: Sat Apr 03, 2010 4:06 pm
by 06pvibe
I'm no expert but I would guess that if its a highly polished surface, a non-abrasive would be the way to go. If a brushed finish, it probably won't matter as long as you follow the lines of the brushing treatment, like going with, instead of against the grain of the wood in woodworking.Is this only happening at the lip of the wheel? And if so, how would you blend in a new top coat? The clearcoat on wheels is usually pretty thick from my experience and would be very hard to feather in a new topcoat w/o stripping the whole wheel and starting over?Another thought I had was stripping them completely and having them powder coated? From what I know of it, and depending who does it for you, it can be very reasonable or quite expensive. You might have to shop around for the best overall deal.This process also adds some weight to the wheel which is always something I consider when choosing new wheels, but may not be as important to you.
