Griding sound in reverse gear
Posted: Thu Jun 05, 2003 1:25 am
by Sub-Vibe-R
Ok, may be I'm paranoiac but about half of the time, when I put my manual tranny in the reverse gear, I hear a grinding sound. The 1st time I hear it, I thought I haven't pressed the clutch properly but I took little more attention at it a, even the clutch to the floor, I hear this grinding sound. Once in the gear, no more sound, it is only when I pull the stck in the reverse position.Is this normal or there's a trouble with my transmission?
Re: Griding sound in reverse gear (Sub-Vibe-R)
Posted: Thu Jun 05, 2003 2:11 am
by ChuckP
I may be wrong but I think its because there are no synchros for the reverse gear
Re: Griding sound in reverse gear (ChuckP)
Posted: Thu Jun 05, 2003 5:51 am
by Chris
Hmm, shouldn't grind at all.Sub's right, there's no synchro (i'm pretty sure) in reverse so, you should always be at a full stop and pause for a couple seconds in neutral before putting it in reverse. When you're really careful and do the above, is it ok? If not, you may have a clutch adjustment prob.
Re: Griding sound in reverse gear (Chris)
Posted: Thu Jun 05, 2003 10:31 pm
by Sub-Vibe-R
Usually, it happend when I'm backing up from my parking spot. So the car is not moving at all and it is in neutral since I parked it up in its spot.
Posted: Thu Jun 05, 2003 11:21 pm
by Pablo1669
I had the same problem once or twice... but if the car is at a dead stop, I don't know what else would be causing that noise. I haven't gotten it since I figured out that was my problem.
Re: Griding sound in reverse gear (Pablo1669)
Posted: Thu Jun 05, 2003 11:32 pm
by Sub-Vibe-R
And once it put the tranny on reverse, I can put it back on neutral then reverse again as much as I want without hearing again the noise. May be the car is lightly going ahead while I put it in reverse. I'll try to do it and keep the hand brake on to see what happend.
Posted: Thu Jun 05, 2003 11:43 pm
by Pablo1669
quote:I'll try to do it and keep the hand brake on to see what happend.you could just keep your foot on the brake pedal, thats always easier then the E-brake.
Posted: Thu Jun 05, 2003 11:55 pm
by Sub-Vibe-R
I'll do it and let you know
Posted: Mon Jun 09, 2003 1:38 am
by tau166
sometimes I get a little "crunch" when putting it in reverse. You have to push it sort of hard to get it to go all the way into gear. It makes a little noise. I've seen many other manual trannies do the same thing. Just for clarification, I park on flat ground and keep my foot on the brake, so the car isn't moving.
Re: Griding sound in reverse gear (tau166)
Posted: Mon Jun 09, 2003 4:28 am
by Keely
I'll third that - Ben, I have the same problem. I thought it was just due to my inexperience driving manual, but I think I tend to be moving just a little when I shift into reverse. I'm going to try the completely stationary thing, although it's really hard for me to be completely stationary in this car!
Re: Griding sound in reverse gear (Keely)
Posted: Tue Nov 29, 2005 12:04 am
by orbix
I'm seeing the same problem with my 2005 base- kind of a 'crunch' sound with a bit of grinding. I'm ocasionally getting a noticeable shudder from the car when shifting into reverse, even with double-clutching.Over in the MatrixOwner forums at http://matrixowners.com/forums...verse, nocivic had to have a new transmission, clutch, clutchmaster, and cables installed to take care of what is apparrently a pretty serious issue.Sounds like it's time to take it in to a dealer...
