Smallest pulley
Posted: Thu Mar 25, 2010 8:57 am
by sikvibe
What is the smallest pulley anyone has heard of being used on the trd supercharger for the 1.8L? I'm thinking about having a custom one made out of billet aluminum at the tiny size of 1.4" or 1.2" and then having the idler upsized one inch..just trying to double my boost.
Posted: Thu Mar 25, 2010 2:54 pm
by midnighthunder89
I am not sure put the higher stages of the cobalt ss has a 2.5"
Posted: Fri Mar 26, 2010 1:36 pm
by sikvibe
Yeah, the trd supercharger comes with the 2.4" I looked around and the smallest I could find was 2.0, but I'm looking to at least double the boost, so I'm not sure if that would do it..anybody have experience with this?
Re: Smallest pulley (sikvibe)
Posted: Fri Mar 26, 2010 8:41 pm
by djkeev
Hmmm,My question would be at what RPM's does the thing explode?Everything is designed to work in a given situation thus there are limits to what it can do. If you over rev it, it can come flying apart.find out before you go modifying too much.Dave
Re: Smallest pulley (djkeev)
Posted: Fri Mar 26, 2010 10:35 pm
by DiveNut
Quote, originally posted by djkeev »Hmmm,My question would be at what RPM's does the thing explode?Everything is designed to work in a given situation thus there are limits to what it can do. If you over rev it, it can come flying apart.find out before you go modifying too much.DaveTrue, the smallest I recall seeing is 2.1" (Water injection is a must). At some point after that you get diminishing returns. The blowers have max RPM...heat buildup will also negate gains. There is a detailed thread, it think in MO in which a member breaks down a lot of the pulley size questions.
Posted: Sun Mar 28, 2010 2:43 pm
by sikvibe
Cool, thanks, I will check there...
Posted: Fri Apr 02, 2010 10:02 pm
by -x-
you can go to about 2.1, with a good water/meth cooling system...after that you're just gonna overspin your blades...and over heat em...
Posted: Fri Apr 23, 2010 11:07 pm
by sikvibe
Yeah The guys over at the MO site say there getting about 9psi of slowness with a 1.9" pulley. I found one at pulley boys for $75 The only problem is they won't respond to my emails..I also read in tuner mag this month that 13 psi is the holly grail that everyone agrees on for max boost on a stock engine, also learned the mazda speed boosted motors are exactly the same ones used in there na cars.
