2009 HU wiring harness?
Posted: Mon Mar 22, 2010 3:05 am
by toronto_user
Hi guys,Could not find information on that topic on this forum. I am trying to install Sony CDX-GT930UI instead of stock radio into Vibe 2009 AWD. Do you know if I can install it without buying adapter for OnStar support? I don't really care about retaining OnStar features. What wiring harness should I get for installation (no support for OnStar is needed)? Thank you very much.SG
Re: 2009 HU wiring harness? (toronto_user)
Posted: Mon Mar 22, 2010 4:41 am
by bigdaddyjosh
You should be able to use the factory wiring harness. Just match the wires from it to the one for your new HU and you should be golden.
Re: 2009 HU wiring harness? (bigdaddyjosh)
Posted: Mon Mar 22, 2010 4:56 am
by toronto_user
Thank you for a quick reply, bigdaddyjosh. I will try that.
Posted: Fri May 13, 2011 1:15 am
by BlueVibe09
Just wondering how the install went? I'm planning on doing the same thing.
Posted: Fri May 13, 2011 1:26 am
by joshuaeb09
If you have the Moons and Tunes or what ever the hell its called, I recommend using the onstar harness. Unless your replacing the factory amp. Using the RCA inputs on it and adjusting the pot I was able to get a very good sound from my Infinity's with the factory amp. If you don't have it then yea screw onstar.
Posted: Fri May 13, 2011 3:00 am
by bigdaddyjosh
Btw. I got the onstar harness from crutchfield for 50 bux. The only reason I got it was for resale value. I dont plan on keeping the vibe forever.
Re: (BlueVibe09)
Posted: Mon May 16, 2011 9:30 am
by dirtbag43
I'm convinced that everyone who tries to bypass the onstar system and use a metra harness gets abducted by suits from the onstar corporation. I have yet to hear anyone plainly discuss a post, aftermarket HU install that doesn't use the onstar adapter. Does it work?!
Posted: Mon May 16, 2011 10:09 am
by dayday
The plain old metra harness mentioned in the other posts works fine. It's so simple, it's really not worth talking about, there's nothing tricky involved. Just match up the wires and plug it in. You will need to directly wire one of the power wires that is not included in the metra harness.
Re: (dayday)
Posted: Fri May 20, 2011 8:47 am
by dirtbag43
thanks dayday. the power wire that needs to be directly wired; does that go to the battery or a fuse box?
Re: (dirtbag43)
Posted: Fri May 20, 2011 12:15 pm
by dayday
Thd one needed is in the car side of the harness so I just cut and spliced it in directly there.
Posted: Fri May 20, 2011 12:24 pm
by TxVibe
I wired mine into the ignition. Easy.
