Which OEM wheels will fit 09 vibe?
Posted: Sat Mar 20, 2010 1:35 am
by file014
Ive got about 11k miles on my 09 base. Ive got the stock 16" steelies with wheel covers and TPMS. I'm wondering what other OEM wheels will fit my car (corolla, matrix, scion, etc) in case I can find some better rims when I have to replace my tires. Also, will 15" Enkei's work (from discount tire)? Id rather have a bit softer ride and im not big on huge wheels.
Re: Which OEM wheels will fit 09 vibe? (file014)
Posted: Sat Mar 20, 2010 1:57 am
by VibeBear
the bolt pattern on our base cars (I have an '09 Base Vibe too) is 5x100mm. There's lots of cars that used this bolt pattern. Matrix, Corolla, Cavalier, Sunfire, Sunbird, various Chrysler products... there's lots of OEM wheels to choose from as well as lots of aftermarket ones.I'm currently on the hunt or a new set of rims to replace my steelies with. The issue I'm having is finding a set of aftermarket 16 inchers I likeI'm leaning towards these factory Cavvy rims: tho I'd rather have these:
Re: Which OEM wheels will fit 09 vibe? (VibeBear)
Posted: Sat Mar 20, 2010 2:00 am
by lovemyraffe
Quote, originally posted by VibeBear »the bolt pattern on our base cars (I have an '09 Base Vibe too) is 5x100mm.The 5x100 bolt pattern is the biggest concern. I'm not sure about 15" wheels. The bolt pattern is the same as the '03-'08 Vibes so you can look at those wheels too. Check your local Craigslist and local tire shops. I picked up some wheels on Craigslist for $50.
Posted: Sat Mar 20, 2010 3:04 am
by midnighthunder89
most vws have the 5x100mm
Posted: Sat Mar 20, 2010 4:24 am
by file014
dang I had a cavalier with 14's but I sold it. will my 15's on my 2002 malibu fit? at least I could try them for size since they are steelies too.
Posted: Sun Mar 21, 2010 7:03 am
by VibeBear
No, the Malibu's rims won't work, the bolt pattern for the 02 is 5x115mm. I believe 16" wheels are the smallest you can go on the Vibe in order to have enough clearance for the brake callipers
Posted: Mon Apr 05, 2010 12:08 pm
by file014
Im thinking stock scion tc rims...they look pretty sweet. Will I have to transfer TPMS?
Re: (file014)
Posted: Tue Apr 06, 2010 1:44 am
by lovemyraffe
You will have to put the sensors on the tC wheels. I have the tC 17" wheels on my Vibe and I did not grab the sensors off my stock wheels.
