valve spring compressor tool
Posted: Mon Mar 15, 2010 12:18 pm
by tunertype
Was wondering if anyone knows a good place to buy the valve spring compressor tool needed for doing a valve adjustment on a vibe gt with the 2zz-ge motor in it. This is the tool that allows you to remove the shims without removing the camshaft or cylinder head.
Re: valve spring compressor tool (tunertype)
Posted: Tue Mar 16, 2010 1:25 am
lucky. in my 1ZZ, you have to remove the camshaft to get to the valve spring (and the stem seals)Looks like you need special service tool (SST) 09248–77010you can supposedly order one from http://toyota.spx.com, just pretend you have a celica (they list it as part number 09248–77010-01) http://toyota.spx.com/detail.aspx?id=245&g=12I have no idea what one costs, or if there is a place where you can rent one.
