CHEAPEST intake available??
Posted: Sat Mar 13, 2010 3:33 pm
by A Psycho Martyr
I saw an Import Tuner article showin how instead of a CAI or SRI, they just used a cone filter on stock intake. Is there a way to do this with the Vibe? Or should I just get a SRI?
Re: CHEAPEST intake available?? (A Psycho Martyr)
Posted: Sat Mar 13, 2010 11:44 pm
by keithvibe
i did this years ago.got a piece of pipe that fit on the inside of the stock intake hose and mounted a cone filter on the other end. didn't do a dame thing though other than the extra noise.
Re: CHEAPEST intake available?? (keithvibe)
Posted: Sun Mar 14, 2010 12:00 am
by A Psycho Martyr
May sound weird...but that's EXACTLY what I want. The noise. So pvc? And would you remember the size? I mean I could measure i suppose, but ya know...thought I'd ask.
Posted: Sun Mar 14, 2010 2:32 am
by sikvibe
Yes, pvc would be the quickest/cheapest route..I've heard that it doesn't sound as good as a metal pipe. You can also open up the exhaust via a header, high flow cats, and a free flowing exhaust all will contribute to a better sound. Just be careful when opening up the exhaust because to little back pressure will cause a loss in power.
Posted: Sun Mar 14, 2010 7:10 am
by mistertwo
RE-READ THE THREAD.. STILL THINK THIS IDEA SUCKS BUT TO EACH THEIR OWN..
Posted: Sun Mar 14, 2010 8:00 am
by northvibe
spectre has some cheap parts
Posted: Sun Mar 14, 2010 9:37 am
by scherry2
save your money and get aSRI or C.A.I. pcv under the hood looks hillbilly.
Posted: Sun Mar 14, 2010 12:25 pm
by sikvibe
I read the same article in import tuner a couple of months ago..and it makes sense the way that they explained it..unfortunately every car is different and jp magazine did the same test a few months ago and got best results using the cold air intake over the stock tube with aftermarket filter attached..I'm just going to upgrade the filter (leaving the stock air box) and a 2.5" exhaust, after this is done I will get a dyno test and post the results.
Posted: Sun Mar 14, 2010 9:53 pm
by bull77
didn't someone do this to their Matrix? had a hole cut in the bottom grille for the intake
Re: CHEAPEST intake available?? (scherry2)
Posted: Sun Mar 14, 2010 11:14 pm
by A Psycho Martyr
@ scherry- I'll paint the pipe gloss white and clear coat it so it is presentable.@ sikvibe- Thanks for the info. Can't wait to see the results
Re: (bull77)
Posted: Mon Mar 15, 2010 1:03 am
by Wolfman213
Quote, originally posted by bull77 »didn't someone do this to their Matrix? had a hole cut in the bottom grille for the intake
http://forums.genvibe.com/zero...age=2about 3/4 of the way down, djb383 has links to pics of his coming from the bottom grilles
Posted: Mon Mar 22, 2010 11:55 am
by tunertype
Get an ebay SRI. It's 24$ plus 15$ shipping that's 40 dollars. To do a custom intake your going to hack up your old intake system making it irreversable and a cone filter at a parts store will cost you at minimum 20$ and a pvc pipe 8$ so you'll save maybe 10$ and won't be as nice looking or as well functioning as a ebay SRI knock off of a 200$ engineered intake.
Posted: Mon Mar 22, 2010 12:39 pm
by mistertwo
Posted: Mon Mar 22, 2010 3:36 pm
by sikvibe
I am currently shopping for my open cone type aftermarket filter and am also looking at plumbing a full custom cool air intake to lower the temps on my supercharger..I should have a post as soon as next month ;o)
Posted: Sun Mar 28, 2010 2:35 am
by high revin
Im running a K&N typhoon short tube and love it, i also built my own ram air system that works real well. I ducted it from the lower grille area up under the battery and to the open end of the filter great set up and not even noticable.
Re: (high revin)
Posted: Sun Mar 28, 2010 4:26 am
by A Psycho Martyr
Quote, originally posted by high revin » i also built my own ram air system that works real well. I ducted it from the lower grille area up under the battery and to the open end of the filter great set up and not even noticable.So YOU'RE the one forementioned in this thread? Such ingenuity!
Posted: Sun Mar 28, 2010 2:49 pm
by sikvibe
I decided to duct down to the lower fairing and just throw in a k&n panel filter replacement..using 2" black cpvc to a 10X3" box on the drivers side lower grill...
