noise!
Posted: Sun Jun 01, 2003 12:00 pm
by shibaman
I had this rattling noise from the right rear of the car. It turned out to be the sway bar that I had installed a few months ago. The right side had come loose because the bolt and nut became loose. I had use a torque wrench to tighten them, but now I may use some lock tight on them. Check those bolts and nuts!
Re: noise! (silverawd26)
Posted: Sun Jun 01, 2003 12:07 pm
by shibaman
Not anything unusual. We do have a lot of bad roads here in Elk Grove. Every time they build some thing they tear up the roads! I really had them tight! I am getting my springs put on the 6th so I will ask the shop about using lock tight on them.
Re: noise! (shibaman)
Posted: Sun Jun 01, 2003 11:17 pm
by slinkston
Heck yeah, that sucks. That is cool you were able to fix the problem before you lost the nut or your swaybar became unhooked or something.If you in fact get some lock nuts, let us know how it works out.Btw, you said rattling, but I'm assuming you did grease the end points right?-Slink
Posted: Mon Jun 02, 2003 1:42 am
by vibenorth
I'm not sure if this is related to your problem but check it out.http://www.safetyalerts.com/recall/a/02/v00138.htm
Re: noise! (vibenorth)
Posted: Mon Jun 02, 2003 4:02 am
by yank dini
Wonder if this is for the early production models?
