Help!!! Amp Install
Posted: Sun Feb 21, 2010 5:00 am
by bigdaddyjosh
Help Im installing an amplified bass tube where can i install the ground wire? Will any screw attached to metal be ok for ground?
Re: Help!!! Amp Install (bigdaddyjosh)
Posted: Sun Feb 21, 2010 7:12 am
by bigdaddyjosh
Nevermind i found a good ground. Now I gotta figure out how to keep all that plastic from rattling.
Posted: Sat Mar 20, 2010 9:26 am
by jscherf92
If youre talking about the spare tire location, you could add some foam sheeting to the underside of the flap, i guess glue it in place. Anything else would probably be better dynamatted or another brand of that stuff.
Posted: Sat Mar 20, 2010 2:17 pm
by jayman2009
yep stoping the rattling is a pita got the back floor to stop now the tailage and the roof rack is. depending on the size of the amp going off a bolt for the seat with the paint sanded away will ground beter
