				Tire Inflation:  Straight Air   vs.   Nitrogen
				Posted: Sat Feb 20, 2010 12:45 pm
				by A Psycho Martyr
				I'm curious as to what the hype is about with Nitrogen in your tires. I just heard about it, but KNOW nothing about it. Anyone with experience willimg to lend advice? Like, does your tread last longer? Does it effect mpg? Is it inexpensive? Basically any pros or cons. Thanks
				Re: Tire Inflation:  Straight Air   vs.   Nitrogen (A Psycho Martyr)
				Posted: Sat Feb 20, 2010 12:51 pm
				by A Psycho Martyr
				I found this on one site. It's just something some guy typed in, but it sounds informative at least.....Filling your tires with nitrogen mainly does two things: it eliminates moisture, and it replaces skinny oxygen molecules with fat nitrogen molecules, reducing the rate at which compressed gas diffuses through porous tire walls. That means, theoretically at least, that a tire filled with nitrogen retains optimal pressure longer, leading to more uniform tire wear and better gas mileage.
				Posted: Sat Feb 20, 2010 1:58 pm
				by tribalman
				hype. that's all it is. same as in paintball. every 2 years we get this nitrogen vs compressed air argument. the air we breathe is 3/4 nitrogen anyways. as for the Quote »Filling your tires with nitrogen mainly does two things: it eliminates moisture, and it replaces skinny oxygen molecules with fat nitrogen moleculesit makes no sense. oxygen has a larger periodic number, ergo it is bigger as it has more protons, neutrons and electrons. http://www.corrosionsource.com...e.gif  oh the hype machine, how i loathe you!!
				Re: Tire Inflation:  Straight Air   vs.   Nitrogen (tribalman)
				Posted: Sat Feb 20, 2010 2:00 pm
				by tribalman
				and you would still need to check the pressure often as temperatures still affect a pure nitrogen vs air; warm temps higher pressures and lower temps means lower pressures in the tires.
				Posted: Sat Feb 20, 2010 3:56 pm
				by star_deceiver
				Take a DEEP breath.... good for you, you just breathed in 78% Nitrogen.If air is leaking out of your tires, it's because you have some sort of leak... the molecule makeup of what you fill the tires with is irrelevent!Tire pressures go up and down with temperature and altitude so check them regularly.Nitrogen inflation, another miracle cure.....brought to you by your local snake-oil dealer!
				Re: Tire Inflation:  Straight Air   vs.   Nitrogen (star_deceiver)
				Posted: Sun Feb 21, 2010 3:41 am
				by Water boy
				Quote, originally posted by star_deceiver »...Tire pressures go up and down with temperature and altitude so check them regularly.Nitrogen inflation, another miracle cure.....brought to you by your local snake-oil dealer!+1
				Posted: Sun Feb 21, 2010 3:43 am
				by ou.grizzly
				Quick readhttp://www.thetruthaboutcars.c...rogen/http://blogs.consumerreports.o....html
				Re:  (ou.grizzly)
				Posted: Sun Feb 21, 2010 4:32 am
				by Caretaker
				Good post grizz.  Goodyear Tire & Rubber Co. is ambivalent about the use of nitrogen. The Rubber Manufacturers Association says it it's a good thing– when it's free. Michelin goes a step further. They recommend nitrogen only for tires used "in high risk environments†like aircraft landing gear and racing.Since it appears the nitrogen molecules leave the tire less often, and the above posting by ou.grizzley does mention racing, I'm sticking with the free nitrogen that Costco provides me.  Even if I have to put in some O2, Costco will evacuate the entire tire and replace it with pure Nitrogen at any time.  Since I work next to one, I'm lucky enought to be able to take advantage of the free rotations and nitrogen fills.
				Posted: Sun Feb 21, 2010 5:12 am
				by A Psycho Martyr
				Thanks for the info everyone. I kinda had a feelin it was hype, just thought I'd get input from you guys. And I'm pretty sure everywhere around here charges for it too. Anyways, thanks!
				Posted: Sun Feb 21, 2010 5:23 am
				by Old Tele man
				...people can't make money selling AIR, so they sell NITROGEN (N2)....why BUY what's free? (until Uncle Sam learns how to tax it)
				Re:  (Old Tele man)
				Posted: Sun Feb 21, 2010 6:36 am
				by keithvibe
				Quote, originally posted by Old Tele man »...people can't make money selling AIR, so they sell NITROGEN (N2)....why BUY what's free? (until Uncle Sam learns how to tax it)I don't know about you but people can make money selling AIR... ever pull in to a gas station where they have an air pump? 50-75cents each cycle
				Posted: Sun Feb 21, 2010 8:02 am
				by northvibe
				I race and still use my own tire pump...meh there is honestly not a benefit to it if I have to pay for it.
				Re:  (keithvibe)
				Posted: Sun Feb 21, 2010 9:57 am
				by ColonelPanic
				Quote, originally posted by keithvibe »I don't know about you but people can make money selling AIR... ever pull in to a gas station where they have an air pump? 50-75cents each cycleThe station closest to home has a wireless debit card reader attached to the machine...  Swipe your CC for $0.75 worth of air, how fricken cool is that?
				Re:  (ColonelPanic)
				Posted: Sun Feb 21, 2010 11:11 am
				by beemerphile1
				Maybe they should sell helium for tires.    It will make our cars lighter and thus have better fuel mieage.    And if you get bored you can always bleed some off and talk like Mickey Mouse.
