Cheap air horn install - Harbor Freight
Posted: Wed Feb 17, 2010 9:34 am
by Thunderscreech
I picked up a cheap air horn from Harbor Freight. Usually $19.99, it was $9.99 so I figured "Why not?" I installed it over by the power steering reservoir:I wired a switch inside so I could sound both it and my normal horn:It's wired to a relay, btw, and I ran my wire through the firewall along with the rest of the main bundle. 40amp fuse at the battery.I'll get a sound clip, it's not a single tone, it alternates between the three horns for now. I'll experiment with combining the air lines. It uses an on-demand compressor that might not be able to supply air to all three at the same time, but it's worth a shot.http://www.harborfreight.com/c...94862
Re: Cheap air horn install - Harbor Freight (Thunderscreech)
Posted: Wed Feb 17, 2010 10:18 am
by star_deceiver
Do they help the drive-thru line move faster? Or at least startle little old ladies?Good on the budget find!!!
Re: Cheap air horn install - Harbor Freight (star_deceiver)
Posted: Wed Feb 17, 2010 10:42 am
by Thunderscreech
Quote, originally posted by star_deceiver »Do they help the drive-thru line move faster? Or at least startle little old ladies?Good on the budget find!!! I'll find out! :DIt's more silly sounding than loud, btw. I'll record it tomorrow.
Posted: Sat Feb 20, 2010 9:11 am
by Water boy
Quote, originally posted by Thunderscreech »I'll find out! :DIt's more silly sounding than loud, btw. I'll record it tomorrow.Ah....but posting it, well that is another story.
Re: Cheap air horn install - Harbor Freight (Water boy)
Posted: Sat Feb 20, 2010 10:27 am
by Thunderscreech
haha, just came here to post the recording and found the above waiting for me. :DHere it is: http://hallert.net/images/airhorn1.mp3
Posted: Mon Feb 22, 2010 2:18 am
by Sublimewind
I don't wanna brag... but... My "other" car.. lollol...
Posted: Mon Feb 22, 2010 2:20 am
by Sublimewind
The video... Wimpy... NOT...
Posted: Tue Feb 23, 2010 4:47 am
by Thunderscreech
Ha, nice! I've added more horns since my last message, looks like I'm doing something very similar to what you are except with various horn lengths so I can get a beefier train sound.
Re: (Thunderscreech)
Posted: Thu Feb 25, 2010 2:28 am
by Thunderscreech
Update! I added the following horn:http://www.harborfreight.com/c...40134It was (is?) on sale for $9.99, so I figured 'why not?' I wired it to a separate circuit from the calliope above and mounted it from the center cross-brace that's in front of the radiator, pointed downwards. It ended up sounding like this:http://hallert.net/images/airhorn2.mp3It was pretty good, but missing a little... something. So I picked up another one (same kit) and swapped out one of the horns with one from the calliope (a different note) and installed it in addition to the one above on the same circuit. It now sounds like this:http://hallert.net/images/airhorn3.mp3All in all, cheap fun that gave me an excuse to crawl around under the car this week. :DI was crossing a railroad trestle recently in the car at the same time a pedestrian was stepping over the tracks without looking around to check for trains. I must have hit a bump, because I accidentally firmly depressed the button for the 4 horns. Whoops! My goal going forward is to avoid the temptation to use it to be an annoying jerk. As this goes against my very nature, I expect it will be something of a struggle.
Posted: Thu Feb 25, 2010 2:43 am
by Sublimewind
LoL... I put mine on an unused foglight switch, so I can turn one set off for most of the time.. turn BOTH sets on for when I wanna be noticed..
Re: (Sublimewind)
Posted: Thu Feb 25, 2010 6:25 am
by joejoev
I just re-installed my OEM horn as alternate to my Stebel Nautilus. It was something I've been meaning to do for quite some time. I kind of missed the little meep-meep...it was fun making fun of it. Anyway, I wired them up through a SPDT toggle switch. Flip the switch up and you get the "nice guy" horn. Flip it down for the "I'll make you poop yourself" horn.
Re: (joejoev)
Posted: Thu Feb 25, 2010 7:34 am
by shortbuskristn
Thats awesome man. I was wanting to put a train horn on mine but i kinda also dig the herby sounding horn.I might need some help with this kinda thing during the summer. Hope you wont be mad if i use ur idea.
Posted: Thu Feb 25, 2010 10:10 am
by Thunderscreech
Heh, go for it! It's cheap fun.
Posted: Fri Feb 26, 2010 5:21 am
by Thunderscreech
Status update: I figured out a way to get the calliope horn to fire all three at the same time. I now have 7 air horns firing at once:http://hallert.net/images/airhorn4.mp3It is... loud.
Posted: Mon Mar 22, 2010 8:31 am
by tribalman
Quote, originally posted by Thunderscreech »http://www.harborfreight.com/c...40134i picked this up today, still 9.99. gonna be installing it hopefully in a few days. i'm confused on the install. i want to pull the stock horn but the instructions say to keep the stock horn. also, the stock horn only has one wire going into it, unless i'm missing one or the bracket is the negative connection. also, i want to keep the center of the steering wheel as the switch for the new horns, does this change the wiring at all? plus, the stock relay's wiring doesn't resemble the new one's at all.
Re: (tribalman)
Posted: Sun Jun 27, 2010 5:12 am
by Water boy
Recently installed a set of cheap plastic horns from Harbor Freight.Added a fused line from the batt than is the main power for the horns, thru the supplied relay.Much better than the OEM.
Posted: Sun Jun 27, 2010 11:37 am
by Thunderscreech
Looks good! How's it sound? Got a recording?
