stock 16 inch wheel pressure
Posted: Fri Feb 12, 2010 11:09 pm
by mike83
they are good year and are 16 inch, I belive 205/55/16what a good setting to have then on? for a good ride and good mpg
Posted: Fri Feb 12, 2010 11:25 pm
by bull77
32 is the normal PSI. I run 40 during the summer and 32 in the winter. I've seen others put in even higher ~45.
Re: (bull77)
Posted: Fri Feb 12, 2010 11:53 pm
by lovemyraffe
When I had my stock wheels I ran 35 year round.
Re: stock 16 inch wheel pressure (mike83)
Posted: Sat Feb 13, 2010 1:04 am
by dcbridgwater
If you have the AWD it is 35 front 32 rear.
Posted: Sat Feb 13, 2010 6:58 am
by TONY TAT2
I run 32 in everything.
Posted: Sat Feb 13, 2010 10:06 am
by vibedrivermatt
I still have my original good year RS-A tires and 16" wheels. I like to run them at 44 psi. I think maybe 42 is the recommended pressure? but really have no idea. Maybe somebody else knows more on that?
Posted: Sat Feb 13, 2010 6:37 pm
by 06pvibe
Personally, I don't think there is a good setting for the BadYears as I hated them.That said, check the sticker on the LS door frame ("B" pillar) for recommended pressures, or read the manual.If they are not satisfactory, do a little experimenting to see what works best for you and your driving conditions. I ran mine a little higher than recommended too, but that will help kill the ride... not that they ride well to begin with.(42-44?? Geez, that's excessive unless Auto-Xing.)
Posted: Mon Feb 15, 2010 11:22 am
by star_deceiver
38-40 in the summer for the RS-A's. I run my Firestone winter tires at 37.
