x
Posted: Thu May 29, 2003 10:16 am
by micheles_bad_vibe
x
Re: squeaky dashboard (micheles_bad_vibe)
Posted: Thu May 29, 2003 1:07 pm
by SweetVibeGTGirl
really? wow! I haven't had any problems yet......... I have only had my vibe since Jan. tho..... How long did you have your vibe before this started happening?
Posted: Thu May 29, 2003 1:42 pm
by Vibe Rater
YES. 3 year bumper to bumper warranty covers that.
Posted: Thu May 29, 2003 9:45 pm
by slinkston
What part of your dash is squeaking? You might be able to fix it yourself. Depending on the date of your cars production, some fixes have been implimented straight from the factory. There was a known problem behind the pod gauges, behind the very middle of the dash creating a metal/metal buzz sound around 4K rpm when running the car hard, and a dash squeak plastic/plastic around the passenger side of the dash behind the glove box.The pod gauges is the easiest fix. The other 2 may require pulling the dash. -Slink
Re: squeaky dashboard (slinkston)
Posted: Fri May 30, 2003 1:49 pm
x
Posted: Sat May 31, 2003 12:28 am
by Vibe Rater
Just a suggestion. Check to make sure your sun visor is securely snapped into place when you hear this rattle. Often, rattles aren't coming from where they sound like they are coming from. A rattling sun visor will sound like the noise is coming from the dashboard.
Re: squeaky dashboard (Vibe Rater)
Posted: Sat May 31, 2003 2:42 pm
x
Posted: Sun Jun 01, 2003 4:50 am
by slinkston
Okay. Please look for your Manufacturer Date. It is not on your driver door, but on the B pillar in the driver door. Like mine says 10/02.Just wondering because maybe it is your gauge cluster that is squeaking. Early Matrix/Vibe have this problem. Mine (10/02) was fixed by the factory.I have a squeak on my dash around the passenger door. I will not take my car to the dealership to get them to fix it because I would rather fix it myself. -Slink
