Engine Cover Bolts
Posted: Mon Jan 25, 2010 8:40 am
by rareorange1
Hey guys:You know those plastic retaining clips near the back of the engine cover holding it down?Well, funny story made short.... I broke one off. However, I happened to notice that the holes they "clip" into are threaded.My question is, does anyone know what size bolt would be used to thread in there? I think its pretty fine thread. Thanks
Re: Engine Cover Bolts (rareorange1)
Posted: Mon Jan 25, 2010 11:26 am
by 06pvibe
Take the remaining one into your local hardware store or big box. They can either measure it and let you know. Or in the case of the Big Orange, they usually have a display that lets you "test fit" your hardware. Based on the size of the clip you should be able to figure out the width and from there it should be relatively easy. My guess though is that they are no bigger than a 6mm, probably a 4-5mm.Are you sure the holes are threaded and not just ribbed to help hold the clip in more securely? I was wondering too: How does the engine cover come off? I see the two acorn nuts in the middle but as yet haven't figured out how to remove those weird looking plastic things at the back of it? Is there a special tool needed for these? How do they clip in?
Re: Engine Cover Bolts (06pvibe)
Posted: Tue Jan 26, 2010 10:39 am
by rareorange1
The holes are indeed threaded. Those plastic retainers are so stupid. They get wrecked as soon as they are removed, like a 1 shot thing. I'll go into Canadian Tire where I work and jack a few different sizes. I was hoping someone else replaced them with stainless steel bolts, and new the size off hand.
Posted: Tue Jan 26, 2010 8:08 pm
by zionzr2
I dont know, I never removed mine.i suppose it would be to easy for them to make the thread type the same as the front bolts so that all 4 would be the same?
Posted: Tue Jan 26, 2010 8:43 pm
I broke both on mine the first time I took that engine cover off, five or six years ago. Never bothered to replace them with anything, You can replace them with better hardware if you like, but you don't need to.
Posted: Tue Jan 26, 2010 9:21 pm
by ajflan
Yeah I never replaced mine.
Posted: Wed Jan 27, 2010 1:47 am
by 06pvibe
What does that cover cover? What's underneath... besides the valve cover, I mean?Is it ugly? I hate useless pieces like plastic engine covers and usually remove them as an easy first Mod.Some companies use so much plastic to cover up the engine you would think they were ashamed of them. Open the hood and all you see is a big expanse of plastic... a sea of plastic if you will. I hate that.
Re: (06pvibe)
Posted: Wed Jan 27, 2010 3:14 am
by rareorange1
Its ugly underneath. The cover is fairly asthetically pleasing.
Re: (rareorange1)
Posted: Wed Jan 27, 2010 5:53 am
by 06pvibe
Good to know!! But I'm sure I will find out for myself sooner or later....
Re: (06pvibe)
Posted: Wed Jan 27, 2010 10:41 am
by rareorange1
Haha.I like how you refer to it as a "mod".It is really ugly underneath. And don't remove it unless necessary, or you'll run into the same problem as me!
Re: (rareorange1)
Posted: Wed Jan 27, 2010 12:11 pm
by hskater26
yep i didnt replace mine either lol
Re: (06pvibe)
Posted: Wed Jan 27, 2010 12:17 pm
judging from how dirty mine gets, the cover will keep some amount of spray and other dirt off the fuel and plug rails., so it's worth keeping for that.
Re: (joatmon)
Posted: Wed Jan 27, 2010 12:33 pm
by hskater26
and never paint it red unless you want to clean it every week
Re: (06pvibe)
Posted: Wed Jan 27, 2010 8:05 pm
by Silversn95
Quote, originally posted by 06pvibe »What does that cover cover? What's underneath... besides the valve cover, I mean?Is it ugly? I hate useless pieces like plastic engine covers and usually remove them as an easy first Mod.Some companies use so much plastic to cover up the engine you would think they were ashamed of them. Open the hood and all you see is a big expanse of plastic... a sea of plastic if you will. I hate that.Depends if the cover has a noise suppression pad underneath or not. Sometimes these covers are strictly to improve the underhood appearance. This first started on higher end vehicles and has trickled down to some cheaper models over the years. Some of these covers are actually used to suppress engine noise. I know the cover on the '09-'10s has the pad. If you have an ear for NVH you might be able to hear the difference with it on or off, but most consumers probably won't know the difference. Usually it helps block the ticking noise made by injectors and/or noisy valvetrains.
Posted: Mon Jan 10, 2011 1:48 am
by silverbullet
orange have you figured out what size works yet? getting ready to paint mine and both my clips are gone hoping to use your idea
Re: (silverbullet)
Posted: Mon Jan 10, 2011 1:59 am
by Salsa Guy
I replaced mine with bolts about 3 months ago (when under going performance mods). I'm not sure the size but I kept them short and added a lock washer. Didn't think it was a good idea to leave those hole open. I now have the cover removed and purchased sparkplug/coil cover.
Re: (rmckinjr)
Posted: Mon Jan 10, 2011 6:00 am
by 06pvibe
As they sayalot on here (Ryan 'star deceiver',) "Pics! Or it didn't happen." LOLzzzz!!
Re: (06pvibe)
Posted: Mon Jan 10, 2011 10:47 am
by star_deceiver
Quote, originally posted by 06pvibe » "Pics! Or it didn't happen." Close.... but after a day or two the mob surfaces!!!
Posted: Mon May 21, 2012 12:29 pm
by joecoolinatl
anyone have the part number of those plastic screws?
Posted: Tue May 22, 2012 11:53 am
by CharlesinGA
They are not "plastic screws" but rather are clips that simply push into the threads in the valve cover. You generally destroy them pulling the cover off. I replaced them with real metric screws and washers.
I used some reduced head, washer faced screws I found at the hardware store (and have 1/16" thick washers under them). The thread is 6mm x 1.00 pitch. The ones I have are 8mm hex head, and are 20mm long (3/4 inch) which is about as long as you want, could easily use 15mm length.
Charles
Posted: Wed May 23, 2012 3:37 pm
by lannvouivre
06pvibe wrote:I see the two acorn nuts in the middle but as yet haven't figured out how to remove those weird looking plastic things at the back of it? Is there a special tool needed for these? How do they clip in?
I removed mine by breaking them accidentally. I'm too short to see them from the front.
Posted: Wed Jan 16, 2013 1:15 pm
by Zvibe2004
if i remember correctly their M6X1, i did the same thing a few weeks ago, i just dont have the bag that the new bolts came in around. take the long valve cover bold off that the acorn nut goes on and check it on one of those little bold size finder thingys at lowes or home depot, that bolt will thread into the back holes on the valve cover perfectly.
