2003 Vibe manual transmission
Posted: Sun Jan 24, 2010 8:58 am
by MelissaAdams
what is the the easiest way to get a transmission out of my Vibe..Husband has the transmission aomost disconnected..Thanks,Melissa
Re: 2003 Vibe manual transmission (MelissaAdams)
Posted: Sun Jan 24, 2010 9:00 am
by lovemyraffe
The easiest way is to have someone else do it. I wouldn't recommend doing it without having a transmission jack available.
Posted: Sun Jan 24, 2010 9:58 am
by chevelle_lover
All of the front wheel drive cars that I have worked on it was easiest to remove the left side suspension and pull it out through the wheel well. Just make sure that the engine is supported properly so that the motor does not flop around in the engine bay.
Posted: Mon Jan 25, 2010 2:40 pm
by SmAshley
Quote, originally posted by MelissaAdams »what is the the easiest way to get a transmission out of my Vibe..Husband has the transmission aomost disconnected..Thanks,Melissamay i ask why you are removing it ? The lemon 2003 Tranny? grinds in 3rd and won't go into 1st & reverse when it has its tantrums... ?
