when to replace brake shoes?
Posted: Sun Jan 17, 2010 10:03 pm
by jefframin
Hi folks!I just replaced the brake pads on my 2003 Vibe, after 85K miles. My car has rear drums.Do the brake shoes tend to need replacing when the pads do? Is there a way to tell how much life they have left without removing the drum?Thanks.
Re: when to replace brake shoes? (jefframin)
Posted: Mon Jan 18, 2010 12:35 am
by lovemyraffe
I don't know of a way to check them without removing the drum. Brake shoes last almost forever. I almost have 85,000 on my '05 and haven't even thought about the brake shoes yet. I wouldn't worry about them unless you are experiencing problems or hearing sounds from the back end.
Posted: Mon Jan 18, 2010 6:40 am
by Caretaker
jefframin: I did my shoes at 121,000 miles. I also had my mechanic flush the brake fluid since I had never had that done either. The point?: the shoes last a long time. you have a ways to go yet I bet.
Posted: Mon Jan 18, 2010 7:29 am
by keithvibe
usually the split is 60/40 60% front 40% backso usually the backs will be replaced on the second change of the fronts.They usually last twice as long as the fronts do "IF" they are properly adjusted.
