3 jl w6 or 1 10 soundstream da vinci
Posted: Mon Jan 11, 2010 10:12 pm
by vibe11
what subs should i put in my car 2 8 in jl w6 and a 10 inch jl w6 all version 1 or a 10inch 2000 watt soundstream da vincithey would be running off of a planet audio 900.1
Posted: Mon Jan 11, 2010 10:20 pm
by DrunkenMonster
10 JL W6, can never go wrong with JL
Re: (DrunkenDixie)
Posted: Tue Jan 12, 2010 4:49 am
by vibe11
and other suggestions, also which ever oner i dont put in the car i am going to sell
Posted: Tue Jan 12, 2010 5:27 am
by audiovibe
What are you wanting the sub to do? Do you want as much boom as possible? or do you want it just to fill the lower frequencies?Aron
Re: (audiovibe)
Posted: Tue Jan 12, 2010 11:26 am
by vibe11
so far i have polk audio mids and highs up front and 2 6 inch elemental designs sub in the rear door speakers. i want good sound quality, and i want to hit the all the different frequencies of low notes and at the same time i want it to be loud
Posted: Wed Jan 13, 2010 4:17 am
by audiovibe
I would either do the dual 8" in a ported or better yet; sell the dual 8" and the sound stream and find another original 10w6 and run dual 10w6. The 8w6 worked great in a 4th order band pass enclosure yielding great SQ and decent output when tuned in the 30-35 HZ range. The downside would be the enclosure would be 1.5 times as big as a ported enclosure.8" can get loud but it will need alot of power and a ported enclosure with a higher tuning frequency, probably somewhere in the 50-60hz range. The trade off here would be not good sound quality. I cant really comment on the sound stream woofer as I am not familiar with any of their newer stuff. At the end of the day I would rate the options as 1. dual 10w6 (if possible)2. dual 8w63. single 10w6Aron
