No headlamps or high beams....
Posted: Tue Jan 05, 2010 12:57 am
by CRW
Fuses appear to be good. I suppose it could be both headlamps going out at the same time. Last time they went out 3 days apart and were replaced at the same time but that was just 6 months ago. Going to get a new bulb and check that but any ideas what could be wrong?Other info --1- fog lamps work2- lamps on indicator on dash works3- high beam on indicator on dash DOES NOT work
Re: No headlamps or high beams.... (CRW)
Posted: Tue Jan 05, 2010 1:01 am
by BlueCrush
What bulbs are you using?
Posted: Tue Jan 05, 2010 2:51 am
by CRW
I ran SilverStar's a couple years ago but didn't get good life from them so I went back to a standard OEM-type grade bulb.
Posted: Tue Jan 05, 2010 3:43 am
by CRW
Found it! Well sort of. Pulled out the dimmer relay thinking maybe this had something to do with the lights. Was going to see how much a new one was and noticed the HEAD relay was the same one. Swapped them. It worked. Swapped back and it worked.I noticed the HEAD relay was really hard to remove. Wondering if the terminals were slightly corroded or something and reseatting did the trick.Regardless its fixed.
Re: (CRW)
Posted: Tue Jan 05, 2010 4:10 am
by BlueCrush
Try out the Phillips Extreme Power bulbs if you want brighter light with a long life: http://forums.genvibe.com/zerothread?id ... um...llips
