Sony HU install ?
Posted: Mon Jan 04, 2010 7:30 am
by dvance06vibe
I just installed a new Sony HU w/the USB front input. BestBuy had to repin the harness in order for the new HU to work. I have noticed that at half volume level the system is overwhelming so I have ordered the scosche converter to tone down the factory speakers. That being said my question is I have noticed that the sub does sound as well as it use too, will the scosche correct this problem? I have the moon/tunes package.
Re: Sony HU install ? (dvance06vibe)
Posted: Mon Jan 04, 2010 7:37 am
by keithvibe
with my set up my "amp turn on" wire wasn't going threw the scosche. So you will have to adjust it threw the radio.
Re: Sony HU install ? (keithvibe)
Posted: Mon Jan 04, 2010 7:42 am
by dvance06vibe
I'm getting sound through the sub it just does not thump like it did with the factory radio.
Posted: Mon Jan 04, 2010 7:44 am
by keithvibe
Quote, originally posted by dvance06vibe »I'm getting sound through the sub it just does not thump like it did with the factory radio.sounds like a trade off. I noticed the same thing with mine.
Posted: Tue Jan 05, 2010 7:28 am
by dvance06vibe
One thing I noticed today is that when the installer repinned the harness he must have reversed the front and rear speakers. When I fade it they are reversed. This will be an easy fix once I install the scosche. Should be able to just change the wires at that point. Would that have an affect on the sub?
