				power steering fluid in 2005 vibe
				Posted: Mon Dec 21, 2009 11:43 pm
				by jbyerley
				Has anyone changed there power steering fluid in there 2005 Vibe.The owner's manual calls for Dexron III automatic transmission fluid, which is red.  The original color I believe was  clear.  Anybody know what the correct fluid is?
				Re: power steering fluid in 2005 vibe (jbyerley)
				Posted: Tue Dec 22, 2009 4:04 am
				by zionzr2
				a Dexron III approved ATF is the correct fluid to use.I use royal purple MAX ATF in mine.
				Posted: Thu Dec 24, 2009 2:09 am
				by MarkM04
				I use Amsoil ATF.  I use a turkey baster to remove old fluid.  I do this every 15k miles or so.
				Re:  (MarkM04)
				Posted: Thu Dec 24, 2009 9:01 pm
				by jbyerley
				Do you remember if the original color was clear or red?
				Re: power steering fluid in 2005 vibe (zionzr2)
				Posted: Thu Dec 24, 2009 9:02 pm
				by jbyerley
				do you remember if the original color was clear or red?
				Posted: Thu Dec 24, 2009 9:16 pm
				by dcbridgwater
				Mine is clear on a 2006, I have also wondered what to put in since factory antifreeze is also different from what the manual says to use.
