Supercharger for AWD model
Posted: Mon May 26, 2003 5:56 am
by teammonkeys
Does anyone knows where i can get a supercharger or anything to make my AWD go faster?
Re: Supercharger for AWD model (teammonkeys)
Posted: Mon May 26, 2003 6:45 am
by NovaResource
Pontiac says the S/C is not for the AWD Vibe. I believe it has to do with the AWD system not being able to handle the extra torque created by the S/C. Also, the exhaust system is different from the FWD base and GT Vibes. I don't believe anybody makes an aftermarket exhaust for the AWD yet but you could always have a muffler shop swap the factory muffler with a lower restriction one.
Posted: Mon May 26, 2003 7:55 am
by satur9
you could get a supercharger or 1zz turbo kit but youd still probably break something like the axles but then youd find the weak point so you can upgrade it and go smoke some wrxs.hope you got a fat wallet
Re: Supercharger for AWD model (satur9)
Posted: Mon May 26, 2003 8:28 am
by Wrx-2-Vibe
Now don't get me wrong I dig my Vibe but....as a previous WRX owner:Vibe .v.s. a rex (FAT CHANCE)!!!!Oh and I plan to force feed my awd Vide!!!
Posted: Mon May 26, 2003 8:36 am
by teammonkeys
Yes, I have a satelite AWD model... I saw a posting on MatrixVibe.net that Borla is looking for AWD model to proto-type an exhaust system. The posting was on Jan of 2003, so not sure if they still need it. I emailed David Borla if his company was still interested. I'll keep you guys update with Borla. I will email Thermal too.As for the Supercharger for the 1zz engine, I'm not even sure were the weak point is. It can be either of all of the drive shaft, axle, etc. How would a machanic know where the weak point(s) is/are?
Posted: Mon May 26, 2003 9:51 am
by satur9
you gotta break a few eggs too make a omlette but if your not willing to sacrifice your car in the name of science then dont. i just dont like telling people stuff cant be done. it can be if your wlling to put forth time money and effort.people said the 2zz couldnt be forced inducted but they were wrong.
Posted: Mon May 26, 2003 11:59 am
by millster
quote:As for the Supercharger for the 1zz engine, I'm not even sure were the weak point is. It can be either of all of the drive shaft, axle, etc. How would a machanic know where the weak point(s) is/are?The main weak point as it is known now is the viscous clutch on the rear drivetrain. According to Toyota and Pontiac it just wasn't designed for too much horsepower. They may just be saying that to cover themselves, but I imagine it's a costly repair to find out.
Re: Supercharger for AWD model (silverawd26)
Posted: Mon May 26, 2003 3:25 pm
by teammonkeys
$2000 for what?
Update with the proto typing
Posted: Thu May 29, 2003 10:32 am
by teammonkeys
I called Thermal and the guy that does the proto typing is busy with a big project and he won't be able to contact me for a few weeks.. Injen has also contacted me, the guy will be on vacation soon and he'll contact me when he gets back.Borla hasn't contacted me yet.
Re: Update with the proto typing (silverawd26)
Posted: Wed Jun 25, 2003 3:52 pm
by teammonkeys
no updates yet...
Re: Update with the proto typing (teammonkeys)
Posted: Thu Jun 26, 2003 5:57 am
by r1ceburner
If you guys start looking around at specs on Cams and things, you can probably find out the differences between the 1zz-ge and the engine in the AWD model. Probably the main difference will be the lift/duration of the cam, and possible a smaller throttle body... but I would bet that the commonality between the 2 engines is remarkably high....Can you disable the rear clutch if it is in danger of getting fried?
Re: Update with the proto typing (r1ceburner)
Posted: Fri Jun 27, 2003 5:43 am
by satur9
it should be the exact same engine. just with worse exhaust routing and additional rotating mass. and no you cant disable the awd unless you start removing parts.
Re: Supercharger for AWD model (millster)
Posted: Sun Oct 19, 2003 2:02 am
by Myself
Yeah, back in feb '02 when I got my 'Trix, the dealer said the 2zz engine had a tendency to blow up the AWD system because of torque when it hit lift, hence the combination wasn't available together. Optimism remains high that in a future model year they might be able to beef up the AWD components. I know it involves a differently shaped fuel tank, but I wonder what else would have to change, to throw AWD under my XRS.
Posted: Sun Oct 19, 2003 8:53 pm
by Wrx-2-Vibe
Yup everyones right (re: awd system failure) myrecomnedation find an old Celica All-trac and use its componets to beef it up. Another ride w/ a good center diff is the old Mazda 323 GTX. Most these parts can be gottne from rally car builders. See Vermont rally car they are awesome. FYI also new half shafts my need made (no biggy plenty of places make them).I superchared a 97 Subaru SVX and ahd to go this same sort of route. It was worth it and unquie car that scooted (if it was a 5-spd and my kids hadnot out grwon the rear seat I's have kept it).
Re: Supercharger for AWD model (Wrx-2-Vibe)
Posted: Mon Oct 20, 2003 9:31 am
by greenfire
I think you guys may be interested in this......... http://www.matrixvibe.net/forums/viewtopic.php?t=3815
Re: Supercharger for AWD model (greenfire)
Posted: Fri Oct 24, 2003 5:40 am
by drunkenmaxx
man, that site takes forever to load, too complicated! i was going to join it while this one was down, but i couldn't stand the 5 minute page load
Re: Supercharger for AWD model (drunkenvibe)
Posted: Fri Oct 24, 2003 8:57 am
by greenfire
I just clicked on it now and it loaded in 16 seconds.
Posted: Mon Oct 27, 2003 12:40 am
by drunkenmaxx
that's too long for me. i didn't mean 5 minutes literally. i like this one because the text will load first and you can read while the pictures still load. since i am at work, i need to be as quick as possible since i do this in between actually woriking.
Posted: Mon Oct 27, 2003 1:01 am
Thanks for the link. Good pictures. SC and CAI on AWD XR? pretty awesome Do you plan to get a dyno run?It will be interesting to see how the AWD holds up with the boosted engine. Keep us posted.Sucks about the lady that plowed into you. Are you back on the road with it yet?Is this you?
Re: Supercharger for AWD model (joatmon)
Posted: Mon Oct 27, 2003 1:25 am
by drunkenmaxx
i would love to see a video of that baby doing the AWD doughnut!
Posted: Mon Oct 27, 2003 9:07 am
by greenfire
Yes thats me in the pic. I have to find a 4wd dyno in order to get a dyno. Also Id be interested to see what my 1/4 mile times are. The exhaust is very restrictive and limits some power...needs to be opened up.Hopefully Ill be back on the road bye the end of the week or early next week.
