Electrical problem?
Posted: Tue Dec 08, 2009 1:13 am
by SublimeVibe
Been having some problems with the electrical I think.The thing is that the headlights and other acc dim when I us ethe heater on High.Yes I know that the draw will cause some dimming lol .The thing is that the blower motor works on and off and sometimes have to give it a little tap to get it to go.Would the blower motor be causing this to happen?Thanks
Re: Electrical problem? (SublimeVibe)
Posted: Tue Dec 08, 2009 10:35 pm
by POPPAJ
Yes.
Posted: Wed Dec 09, 2009 12:34 am
If the blower is sticking where you need to kick it to get it freed up, then it could be the problem. Could be other things as well, such as corroded battery terminals, a loose of poor ground at the block, etc.
Posted: Wed Dec 09, 2009 9:22 pm
by SublimeVibe
I'll check around under the dash around the blower and glove box.If nothing that I can see I'll get the blower changed.Thanks for the replies.
