I need Battery Positive term
Posted: Wed Nov 11, 2009 8:59 am
by SilverVibe03
Hello All,I need a Battery Positive term mine has been eaten by battery acid I need a replacement. Anybody know a good place to order one online? Thanks You
Re: I need Battery Positive term (SilverVibe03)
Posted: Wed Nov 11, 2009 9:02 am
by keithvibe
the actual battery post of the connector that is connected to a wire from the car?If it's the second one you can buy one in any parts store for a few bucks. No need to order it online.If you are talking about a battery post they you will need to replace the whole battery.
Posted: Wed Nov 11, 2009 9:27 am
by SilverVibe03
I need the postive connector,any type will fit.I thought I needed the factory one?
Re: (SilverVibe03)
Posted: Wed Nov 11, 2009 9:33 am
by keithvibe
walk in to any autozone and go to the counter and ask them for a battery post connector. they will give you one that will cost you about 5bucks.in this case factory='s any aftermarket connectorthe real question would be what caused it to melt and require you to need a new one? why was there so much acid on it?
Posted: Fri Nov 13, 2009 1:36 am
by Sublimewind
Napa... I have a full write up on this very same subject... You need to replace the battery as well... The whole reason it's been eaten by acid is because it's leaking...
Re: (Sublimewind)
Posted: Fri Nov 13, 2009 2:42 am
by scherry2
Quote, originally posted by Sublimewind »Napa... I have a full write up on this very same subject... You need to replace the battery as well... The whole reason it's been eaten by acid is because it's leaking... really? hmmm I have the same problem on my '03 after I installed mods. I noticed it, changed the terminal, still did it. after 6 years I changed the battery (cause it finally wouldn't hold a charge) and with a new battery it still does it. I can tell you for sure neither battery "leaked".
