CEL reporting bank 1 lean, need help
Posted: Fri Nov 06, 2009 7:31 am
by lorszulak
need help diagnosing which part is the culprit.04 vibe gt with fidanza flywheel, act stage 2 clutch, short ram intake and borla exhaust. Light came on around 120k, now at 140k. Light use to come on and off but for the most part has stayed on consistently. Seems to be a idle issue sometimes, drops to 100 rpm and floats around then comes back to normal. Also have a severe loss of power. Ive already replaced both o2 sensors and cleaned the MAF sensor. I am suspecting the CAT...any help would be much appreciated.
Re: CEL reporting bank 1 lean, need help (lorszulak)
Posted: Fri Nov 06, 2009 9:34 am
by Easton091
Have you had it scanned and if so what is the code?
Re: CEL reporting bank 1 lean, need help (Easton091)
Posted: Sun Nov 08, 2009 4:41 am
by lorszulak
My buddy used his multi scan tool, dont remember if it had a number. I do remember it reporting "bank 1 lean". Where do I get it scanned for free? I tried autozone but california passed some law recently where they are not allowed to do it. I couldnt believe it, so I went to other part store chain's too and they said the same. Is there suppose to be a number? I would think the dealer would charge...
Posted: Sun Nov 08, 2009 6:41 am
could be P0171System too Lean(Fuel Trim) (Bank 1) Air induction system PCV hose Injector blockage Mass air flow meter Engine coolant temp. sensor Fuel pressure Gas leakage on exhaust system Open or short in oxygen sensor circuit Oxygen sensorECM
Posted: Sun Nov 08, 2009 2:07 pm
by star_deceiver
Your fuel pump is on it's way out
Re: CEL reporting bank 1 lean, need help (star_deceiver)
Posted: Mon Nov 09, 2009 2:14 am
by Sublimewind
Quote, originally posted by star_deceiver »Your fuel pump is on it's way outThere is ZERO way/reason for you to determine that.. OP, You really need to know the code... I just picked up a basic code scanner for $60 at autozone.. it reads and clears, that's it... Knowing the code is key...
Re: CEL reporting bank 1 lean, need help (Sublimewind)
Posted: Mon Nov 09, 2009 10:04 am
by star_deceiver
Severe loss of power, idling problems. Since he's replaced the o2 sensors I'm assuming that he's already checked the simple stuff (plugs, clogged air filter, maf sensor).My friends 93 civic had the same problems. After changing most of the sensors, plugs, wires, distibutor, filters, the problems were still there, nothing helped. Put in a new fuel pump, all problems solved. And all this with no cel.
Posted: Mon Nov 09, 2009 12:58 pm
by jake75
Quote, originally posted by lorszulak »My buddy used his multi scan tool, dont remember if it had a number. I do remember it reporting "bank 1 lean". Where do I get it scanned for free? I tried autozone but california passed some law recently where they are not allowed to do it. I couldnt believe it, so I went to other part store chain's too and they said the same. Is there suppose to be a number? I would think the dealer would charge...I wonder what that's all about. Maybe there was an issue with selling stuff not needed due to the code read outs. However - reminds me of a USDA regulation that won't allow a cattle rancher to test his own cows for mad cow disease.- and the Court upheld it!
