Had good luck with my 03
Posted: Wed Nov 04, 2009 9:25 pm
by chevman-67
changed my front passengers side strut at 130,000 kms,changed both front wheel bearing at same time,I have also broke both plastic door switch assembleys inside cheap plastic clips,a few rattles and a rear brake sqeek when I apply the brakes.All minor stuff in my books and quick fixes eccept the wheel bearings a garage job unless you have the tools as they are pressed in.I love my vibe.Down falls are bad blind spots and sunvisors suck.they could have been a bit bigger.
Re: Had good luck with my 03 (chevman-67)
Posted: Thu Nov 05, 2009 12:24 am
by 03VibeOttawa
Quote, originally posted by chevman-67 »changed my front passengers side strut at 130,000 kmsVery similar to me, I had a blown driver side strut in the 130,000kms range, and took that oppurtunity to upgrade all of themQuote, originally posted by chevman-67 »Down falls are bad blind spots and sunvisors suck.they could have been a bit bigger.Never thought of the sunvisor complaint before, but I would add that the exterior door handle design is a fail. (on my second driver handle, and have to ginger it, or I will rip it off again).
Posted: Thu Nov 05, 2009 1:03 am
by bull77
Quote, originally posted by chevman-67 »I love my vibe.Down falls are bad blind spots and sunvisors suck.they could have been a bit bigger.do the 03 visors extend out like other years?
Re: Had good luck with my 03 (bull77)
Posted: Thu Nov 05, 2009 10:51 am
by chevman-67
nope sure wish they did though and they are to short and dont go far enough to the center of the windshield that dark smoked area just dont cut the sun down atall.all mine do is swing no extensions but all the other options are great.knock on wood my door handels are great.(knock knock).forgot to add ac compressor failed but warantee covered it.
Posted: Mon Nov 23, 2009 1:38 am
by Whelan
My issue is not with their length, although my 05 extend out from the bar. It is the width. They don't extend far enough down when folded. I find myself sitting up higher to keep the sun from my eyes at certain times of the day. Very annoying.
