Interioir Scratches
Posted: Sun Nov 01, 2009 12:43 pm
by kupecky
I have a 2010 GT and I find the interior to scratch super easy. This is happening mostly around the passenger door or glove box... usually from people in the passenger seat. I've tried Armor All protective wipes but that doesn't seem to help. Has anyone else experienced this?Thanks
Posted: Sun Nov 01, 2009 12:58 pm
by ou.grizzly
I scratched the center console on our 09 Vibe, but that was because the ring on my left hand hit it.
Re: (ou.grizzly)
Posted: Sun Nov 01, 2009 3:25 pm
by star_deceiver
The centre console has been nailed by seatbelts a few times, around the ignition is all scratched... it's cheap plastic, whacha gonna do?
Re: (star_deceiver)
Posted: Sun Nov 01, 2009 8:56 pm
by 09vGT
I posted something about this awhile ago.. no fix that I could find.. Be careful with the plastic around the ignition because that is $400 worth of cheap plastic .. (had mine replaced under warranty).
Re: (09vGT)
Posted: Mon Nov 02, 2009 2:02 am
by lowincash
wth $400 for that piece of plastic?? yikes! mine is scratched too lol
Re: (09vGT)
Posted: Mon Nov 02, 2009 3:11 am
by ou.grizzly
Quote, originally posted by 09vGT »I posted something about this awhile ago.. no fix that I could find.. Be careful with the plastic around the ignition because that is $400 worth of cheap plastic .. (had mine replaced under warranty).You prob never did add a rubber or felt product around the ignition like suggested.
Re: (ou.grizzly)
Posted: Tue Nov 03, 2009 8:12 am
by vibolista
Plastic scratches easily. Just be careful with it. Aim a little before you attempt to shove the key into the lock. You can stick your index finger over the tip of the key to feel where it should go. Not too tough to do and once you get use to it... it becomes easy and you get no scratches around the ignition, or doors if you ever have to use the key to unlock. Heavy metal bling is death to the plastics on the doors and any other plastic that comes within range. As a matter of fact, bling can scratch just about every surface, from paint to glass. Too bad they don't have some kind of rubber or durable vinyl you can use to cover the interior plastic.
