Replacement bulb for license plate light
Posted: Wed Oct 28, 2009 10:07 am
by jdale
2005 Vibe. Owners manual mentions nothing about this bulb. there are two of them and one is burnt out. Did a search on this forum and found part #168. What bulb do I ask for at an Auto parts dealer and how do I gain access to change it?Thanks for any and all help!
Re: Replacement bulb for license plate light (jdale)
Posted: Wed Oct 28, 2009 10:16 am
by star_deceiver
There's either a screw-on outer cover or you can pull the bulb from a panel inside the car... (Have a look, it's one of em!)
Posted: Wed Oct 28, 2009 10:38 am
by jdale
Thank you so much! Have to replace it in the A.M., granddaugther taking driving test. All lights must work! Thanks again
Re: (jdale)
Posted: Wed Oct 28, 2009 11:17 am
by 03VibeOttawa
nice of you to lend your car out
Posted: Wed Oct 28, 2009 10:43 pm
welcome to genvibeQuote, originally posted by jdale »2005 Vibe. Owners manual mentions nothing about this bulb. there are two of them and one is burnt out. Did a search on this forum and found part #168. What bulb do I ask for at an Auto parts dealer and how do I gain access to change it?Thanks for any and all help! an auto parts store will know what a #168 bulb isI recently had to replace mine, and
http://forums.genvibe.com/zerothread?id=21999 helped.
Posted: Sat Apr 28, 2012 12:07 pm
by Mbala
2007 Vibe:
I removed the plastic cover in the back of the car, unplugged the wire, and attempted to release the white plastic holder with the bulb by twisting it left. Could not move it. Yes, it should turn left to release. Took pliers, grabbed the plastic, twisted, cracked the top of the plastic. Bad idea.
Then I pushed the two black pieces of plastic inward to release the entire assembly. Pushed it forward and down - it actually slides out quite easily if you get the angle right. I got a good look at the whole setup and this time managed to twist the white plastic holder for the bulb with pliers with minimal damage.
I recommend getting the whole assembly out - much more comfortable to deal with it once it is lying in front of you. If I did that to begin with, I would not end up with cracked plastic.
Posted: Sun Jan 13, 2013 5:57 pm
by Mojo72
Thanks for the tip on replacing a license plate light bulb. By pinching the black tabs at the ends of the light assembly, I was able to lift out the whole unit then see where I could remove the white stem by turning it counter clockwise by approximately 15 degrees. For some reason, I couldn't get the stem to screw off without removing the whole light. The access panel was pretty easy to pry off with a small nail pull, but I did manage to break off one of the 6 tabs. Oops!
