What's the restrictive part in the exhaust?
Posted: Tue Oct 27, 2009 10:57 am
by DrunkenMonster
I know in the Bonneville I had it was the cat. I am wondering if its all or certain parts on the Vibe's exhaust. There's no sense replacing it all if some of it is good and not make a difference upgrading.
Posted: Tue Oct 27, 2009 11:14 am
by B14CK_H4WK
well you have two cats and a resinator
Re: (B14CK_H4WK)
Posted: Tue Oct 27, 2009 11:36 am
by lovemyraffe
The monkey that hides in there occasionally.
Posted: Tue Oct 27, 2009 12:42 pm
by northvibe
usually its the downpipe and cats. but on this 1.8NA engine... the exhaust header is fairly restricted then you could 2" the rest of the exhaust to gain some.
Re: (B14CK_H4WK)
Posted: Tue Oct 27, 2009 1:58 pm
by Tommychu
Quote, originally posted by B14CK_H4WK »well you have two cats and a resinatorThe Resonator doesn't restrict flow much, if at all. it's essentially a short section of bigger pipe whose basic purpose is to reduce exhaust noise inside the car. The cat doesn't last as long as some and it both gets more restrictive and throws the computer for a loop when it poops itself. but such is the case with a lot of cars out there.
Posted: Fri Nov 06, 2009 1:14 pm
by jerseymike68
Quote, originally posted by B14CK_H4WK »well you have two cats and a resinatorThe Resonator doesn't restrict flow much, if at all. it's essentially a short section of bigger pipe whose basic purpose is to reduce exhaust noise inside the car.The magnaflow catalytic converter doesn't last as long as some and it both gets more restrictive and throws the computer for a loop when it poops itself. but such is the case with a lot of cars out there.I know in the Bonneville I had it was the cat. I am wondering if its all or certain parts on the Vibe's exhaust. There's no sense replacing it all if some of it is good and not make a difference upgrading.2005 Vibe Base with M&TKenwood KDC-MP342UAvital 4103 Alarm/Remote Start18" Equus EQ 05 Wheels with General Exclaim UHPK&N Panel Air Filteralso if your catalytic converter goes bad you could be running rich or justt the o2 sensor
Posted: Wed Apr 14, 2010 2:31 am
by DrunkenMonster
Let me rephrase. What can I replace that I will see a improvement in fuel economy.
Re: (DrunkenDixie)
Posted: Wed Apr 14, 2010 7:45 pm
by djkeev
Quote, originally posted by DrunkenDixie »Let me rephrase. What can I replace that I will see a improvement in fuel economy.The SINGLE best think to improve / change for fuel economy is how you operate your Right Foot.I won't go into it here, it is very well hashed over, but driving "style" makes a HUGE difference in fuel economy.I've got an 07 automatic with a 1.8I've burned up fuel to the tune of 23 MPG and I've nursed out 36 MPG's. It all depended upon how I drove in a given situation.Dave
Re: (djkeev)
Posted: Sat Apr 17, 2010 12:39 pm
by mac99d
What's the restrictive part in the exhaust? The whole thing. Cut it off go with headers and 3 inch no cat all the way out. Now thats some free flow. lol
