blower motor no worky
Posted: Fri Oct 23, 2009 11:41 pm
by jasony0423
Hi,The blower motor on my car stopped working last night. Went to turn on the defroster, and nothing. Turned the fan to high, and still nothing. This morning, it works, but only on high. No other speeds. It's getting close to winter, so I'm not gonna be able to go without defrost and heat. Anyone heard of this before?
Re: blower motor no worky (jasony0423)
Posted: Sat Oct 24, 2009 12:17 am
by metso5
yes its just your blower motor resistor,,,i think it takes 30 seconds to replace
Posted: Sat Oct 24, 2009 1:56 am
by ou.grizzly
Re: blower motor no worky (ou.grizzly)
Posted: Sat Oct 24, 2009 8:06 am
by jasony0423
Quote, originally posted by ou.grizzly »Compliments of MoonStoneMike: http://forums.genvibe.com/zerothread?id=36099Thread on the search feature: http://forums.genvibe.com/zerothread?id=4856Thanks.When you type in blower motor not working in search, you get this:No Results FoundYour search for blower motor not working returned no results.Please try different search criteria or a different data set.Once the answer was given (blower motor resistor) then it works. Just didn't want you thinking that I didn't search first.
Posted: Sat Oct 24, 2009 8:13 am
by ou.grizzly
Quote, originally posted by jasony0423 »Thanks.When you type in blower motor not working in search, you get this:No Results FoundType in "blower" and get the following results http://forums.genvibe.com/zerosearch
Posted: Mon Oct 26, 2009 11:08 am
by jasony0423
Well, it wasn't the resistor. I got one and changed it today. Smae problem. Here's more detail I noticed.When I turn the fan on, it doesn't work at any speed anymore. However, if I turn the fan speed setting to anything other than off, it goes to a higher rpm, and something turns on. It does this regardless of whether the a/c is on, heat, or just the blower, however, it doesn't blow air, no matter what.
Posted: Sun Dec 13, 2009 10:14 pm
by 05VibeGuy
Hi Jasony0423, just wondering what your final diagnosis was for your car? I'm having the EXACT same issue as you on my Vibe and in googling the issue, I came across this thread.
Re: (05VibeGuy)
Posted: Sun Dec 13, 2009 10:22 pm
by ou.grizzly
Quote, originally posted by 05VibeGuy »Hi Jasony0423, just wondering what your final diagnosis was for your car? I'm having the EXACT same issue as you on my Vibe and in googling the issue, I came across this thread. He has not been active for over a month, especially considering other members here have asking him questions and he has not responded. Apologies. May want the fix that is suggested.
