Help installing autostart
Posted: Fri Oct 09, 2009 11:33 pm
by MountainMax
Hey guys, im trying to install an autostart in my 2009 vibe using a datalink tbsl-ko security bypass module. I am having trouble finding where to put the two wires from the bypass module, it shows them connecting to pins 4 and 5 on a 7 pin connector but I cannot find a 7 pin connector on the dam car. Wndered if any of you came across this before. Please reply asap if you can help me out. thanks
Re: Help installing autostart (MountainMax)
Posted: Sat Oct 10, 2009 11:55 pm
by VibeBear
Can you post a copy of the installation pic? Most bypass modules I've seen connect to the ODB II connector under the dash
Posted: Sun Oct 11, 2009 1:50 am
by MountainMax
Yeah, some do, the ones with two way ecm communication, this model does not allow that. I found my problem, the flash in the modules are at 1.5 and they had to be updated to 2.0 to work.
Re: (MountainMax)
Posted: Sun Oct 11, 2009 1:51 am
by MountainMax
Posted: Sun Oct 11, 2009 5:24 am
by lowincash
hmm does the remote start need a separate remote control to turn on? or can you still use the remote on the key?
Posted: Sun Oct 11, 2009 6:37 am
by MountainMax
It has it's own remote.....
